Compaq Presario 700  PC Notebook
Problem for Compaq Presario 700 (470024-192) PC Notebook
Not turning on
By castatroy on Feb 06, 2008
I have this problem with a presario 700 laptop brought in by a client. Apparently this thing was working fine until he accidentally dropped it now it wont work. what happens is that it comes on but wont display anything. the problem cant be the lcd because I have tries to plug in another monitor to it still nothing I suspect that the problem might be with the processor because when I take out the processor it acts the exact same way as when the processor was plugged in. the battery though keeps flashing red (this I think means that it is charging but never gets full and the machine will not switch on if it is not connected to the power source. what can I do to check exactly what the problem might be. Thanks
regards
Casta.T
Solution #1
posted on Feb 11, 2008
Somewhat Helpful)
danasaur
Rank: Guru
Rating: 87%, 109 votes
The laptop component most likely to be damaged by a drop is the HDD. Unless the screen is hit by some object during the fall, it is way down the list of likely suspects.
The HDD has a maximum G-force shock rating, and it is rarely very high. If the laptop was running (or suspended/hibernating) when it was dropped, the odds the HDD is damaged DOUBLE.
The only laptop HDDs I have ever seen that can survive a drop while running are Samsungs, because most new ones have a sensor that detects zero gravity (whjat you get in a fall) and locks all moving parts before it hits. One 120gb Sam in a USB case that I have has been dropped several times, while running, and still has zero bad sectors!
Anyway, since HDDs are easy to remove, I would definitely suggest removing the HDD and trying a known good HDD before you proceed with any LCD suspicions. Even if the HDD is loaded already with somebody else's OS (rare that it will fully boot/reach desktop then) you will still get a screen and some indication that the OS is loading -until it encounters different drivers that cause a critical halt. So once you see that works, buy a new HDD and you are most likely going to be OK
Was this helpful?
Yes
No
Solution #2
posted on Feb 08, 2008
Somewhat Helpful)
daemonguy
Rank: Wiz
Rating: 82%, 157 votes
May be because of Loose end connections in the Ram Slots , try to de assemble each part and assemble again
Hope this would help
Was this helpful?
Yes
No
Solution #3
posted on Feb 07, 2008
Somewhat Helpful)
IB4G2008
Rank: Wiz
Rating: 82%, 2427 votes
Dropping a laptop, can cause quite a few serious issues. Sounds to me like the lcd is compromised, and will require a replacement. The uP swap will have little to do with it. The membrane board that supplies the LCD is fragile to the touch, so dropping the unit will make it quite suspect.
Got Backup?
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
soney
Rank: Guide
Rating: 68%, 8 votes
It may be the problem related to power supply.check the cmos battery also.
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario 700 PC
Questions and Unsolved Problems for Compaq Presario 700 PC
Do you recommend Compaq Presario 700 (470024-192) PC Notebook?
Answer
Answer
hinges cover crack , lcd ok... hinge brackets broken
Answer
I have lost audio on my laptop, I have tried to reinstall drivers, done system recovery 3 times and... (More)
Answer
my laptop wont allow me to access the internet and i have tried everything. HELP PLEASE
Answer
i have a compaq c700 laptop, sometimes it wont shut down or select a program, I have to switch it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Presario 700 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
