Help me pls1
When i turned on my tv but with only just an antenna, it is o.k. but if you put a cable in it the picture runs up and down
Coba aja bagian ic croma /syinkron gambar di tepatkan setelanya karena
bagian output if vedio tidak stabil mengeluarkan signyal vedionya maka
tidak akan bisa syncron antara vertikal dg lainya
Posted on Feb 08, 2008
    President:
  • 1,284 Answers
Sounds like off air signals are quite strong where you are. If the issue happens when connected to cable tv only, then I suspect that you have a bad splitter/ground block or the fittings outside are corroded. Call the cable company to have them fix the issue as the tv in almost all cases isn't the issue.
Posted on Feb 07, 2008
    New Friend:
    Problem Solver:
  • 15 Answers
Ok two things here, if it a realy old tv, check and see if it has a vert control knob that you will use to adj the vertical rolling.
are you on a cable box? if so bypass the box and plug the cable directly into the tv bypassing the box, if this works box bad get exchanged.
2nd if it is a new tv, try this, when putting you cable to the tv do it slowley and watch the tv, as the cable gets close to rf imput on tv dose the pix get clearer untill to cable is pluged in all the way? if so you have agc overload and the simplest way to fix this is get a antenuator, this is a small screw on device that will cut the siginal streght down and will stable you picture.
Antenna not working anymore?
talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
Jan 20, 2016 | Westinghouse Televison & Video
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Feb 10, 2015 | Vizio S5430W-C2 54-Inch 3.0 Soundbar Black
Digital tv tuner not displaying picture
. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Panasonic PT-50LCX63 50" Rear Projection...
I cannot get a picture on any channel. Not hooked to cable. No antenna. What is the problem?
Most of the TV sets have " Picture Mute" feature which means; if no signal exists on either Antenna plug or on Video input (RCA jack) no picture at all.Blank screen..no audio as well..all MUTED..
to test it ,play a DVD ,you must have pictures and audio together..
Use an antenna ( even a piece of plain cable will work ) ,and run "search" ,you must receive some TV channels thru AIR.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Toshiba MD13N3 13 in. TV/DVD Combo
WE DISCONNECT OUR SATELITE hOW DO WE GET REGULAR TV
You must have these first.
1. Aerial antenna - buy this at your local home depot. Any aerial antenna available will be fine. Please see the sample picture.
2. Antenna wire (RG-6 cable wire) - connect one end of this wire to your aerial antenna and then the other end to your tv.
3. RG-6 connector - other end of the cable wire must have a this connector to attached it securely to your TV.
Some Aerial antenna has a cable wire packaged, this is much better than to assemble #2 and #3.
After the connection had been done, go to the menu on the tv, scroll down to antenna connection and then press auto tunning to saved all the viewable channel in your area.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 21, 2011 | Hisense LHD3204US 32 in. LCD HDTV
Power antenna The antenna motor runs but the
If you have to people that are patient you can try to as you turn the radio on and of have one guy on the inside and one guy out take the nut off the top of your antenna and pull it out there is a geared cable inside as you turn the radio off feed the plastic cable in make sure you put the nut back on before turning the radio back onb good luck
Sep 11, 2010 | 1994 Buick LeSabre
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Tv repair
Your tuner (in the tv menu) is probably still set on "cable", but it should be set on "off air" or "antenna". When you first turn it on, it looks for a cable signal and when it can't find one, it automatically searches for an "off air" or "antenna" signal. Once it finds a signal, then it stays on and runs ok. If you shut it off, then it has to go thru all this again.
There is a very high probability that this is your problem (about a 99.99% chance). Just go into your menu and select "tuner" or tuning or "input select" or something in that "neighborhood". Different TVs call it different names, so just put in on the option other than "cable". If you ever get cable back again, then, of course, you have to go back into your menu and set the tuner to "cable. Hope this helps.
Keever
Mar 08, 2008 | Televison & Video
Tv has no picture
sounds like a antenna block problem or a tuner?? Now Im wondering if this set has mutiple antenna inputs?? if it does then the antenna input switch is on the wrong mode.
Apr 06, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
