Question about Sebo Air Belt C3.1 Bagged Canister Vacuum
Sebo airbelt k1
Dear Sir,could you perhaps help me?we have a sebo airbelt k1 in for repair with flex problems-how do you split the chassiss from the casing?I suspect the rear fixing screws are under the castors but dont want to force&break any plastic items before the things even apart-grateful of any help-Paul.
  • blackjack887 Feb 07, 2008
    Thanks for that reddevil6,what a great site 'fixya' is and its good to know guys like yourself are out there and happy to share a problem-the Sebos apart now and iv just stripped out the flex reel,what a crafty design-those sliprings with the wipers to carry the mains voltqage?anyway,hope shel be up&running shortly.Thanks again Paul.
  • Anonymous Mar 13, 2014
    fix retractable cord sebo airbelt k1
    President:
  • 1,673 Answers
No screws under the castors. There is 3 case clips, the bumper hides them, maybe this picture will help:
Posted on Feb 07, 2008
My Sebo D4 seems to have no power going to the hose. I think it's in vac, because I've tried two different hoses. Any clue how to dIY?
Here is a rather COMPLETE Manual with nice details! Start here:
https://www.natlallergy.com/images/art/SEBO%20AIRBELT%20D4%20Owners%20Manual.pdf
Also see this REPAIR video:
Servicing Sebo Automatic X4
it's rather lengthy but lots of good insight!
See this too and pay SPECIAL attention to "AIRBELT D4"!
http://www.sebo.us/how-to-videos/how-to-videos.aspx
Anthony
Apr 04, 2018 | Sebo Vacuums
Changing sebo telescopic slide button, how to
go to :http://www.sebo.co.uk/support/downloads/
download your instruction manual, and proceed according with common sense forchange your parts.
God bless you
Jul 15, 2012 | Vacuums
THE BRUSH ON MY HEAD FOR THE SEBO K1 HAS STOPPED SPINNING WHY???
Check the brush roller at each side to see if threads are wound around it. Also, check the brush to see if there are threads wound around it. This is what generally stops the brushes from spinning. It will take sometime to unwind the threads/lint and you may need scissors and tweezers to fully remove all of them but it will be worth it!
Nov 01, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
How to fix sebo air belt k1 hoover
what is the problem first, I need to know before I can help
Jul 29, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
Taking off the bumper from A Sebo K1 Airbelt
First, remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver). The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else.
Apr 10, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
My Sebo AirBelt K1 just stopped working
I work with a Sebo dealer (in the UK), where we repair all makes of vacuum cleaner. It's testimony to the quality of Sebos that in several years I've only had one of this model to repair (so my memory is somewhat sketchy). However, from first principles, the finger of suspicion points to two likely causes of this problem. First, the copper wire may have broken within the flex - this commonly happens where the flex is subject to both stress and tight bending, which is the two extremities (where the flex enters the plug, and where the flex joins the rewind reel). You will need a continuity tester of some kind to check this, of course. The flex may be visibly damaged, but often there's nothing visible externally. Second possibility is that one or both of the motor's carbon brushes is worn out. You will need to get them off the motor to check. Check both - they can sometimes wear very unequally - a new one will have about 2cm of carbon exposable, whereas a worn one can have nothing left at all. As for what's economically replaceable... it depends what you can do for yourself. In the UK a new flex complete with rewind reel will set you back about £45. However, it is possible just to wire in a length of new flex provided you make sure that any connection you make is good, safe and not subject to stress from winding and unwinding. As for the carbon brushes, in the UK they are about £5 each. For a complete new motor you'll not get much change from £100.
I hope this helps. If you need me to try again just post a reply, giving any more information you can, and I'll see what I can do. Good luck!
Jan 13, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
I have a Sebo air belt K1 How do you open the outer casing so as to replace the electric cable.
OK, but be warned... it's not so difficult getting the thing apart, but making a neat job of reassembly has been known to drive grown men to despair. And that's because you have to remove the airbelt. But first things first:
1. remove the hose
2. remove the hose-retaining ring
3. remove the flap that covers the green filter.
4. remove the screw beneath that flap nearest to the handle (there's a deeply recessed screw on the other side, but you can ignore that)
5. remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver)
6. this is where it begins to get interesting. The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The first challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else. (The second challenge is getting it back neatly!)
7. remove the ends of the foam strip far enough to reveal two plastic clips that hold top and bottom of the body together
8. prise those clips off with a screwdriver.
9. it should now be possible to lift the top cover off. It can be a bit fiddly getting it off over the neck where the hose plugs in, but it does come off.
10. the cable rewind spool is now revealed in all its glory.
11. if you've found my advice helpful so far, here's a final piece... don't try to fit a new cable to the old spool - fit a complete new spool.
12. good luck!
I value feedback, so please remember to rate this response.
Central vacuum cleaner problem
Fasco has been out of business for several years. The motors are still available. You will need to find the model number off your old unit. Once you have that model number you can find the replacement motor at one of these websites.
https://www.centralvacuumstores.com/motors/fasco.php
http://builtinvacuum.com/help/fasco/motor.html#motor
Jun 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
No power
This is a dead motor. the electrical motor is experiencing windings failure and will have to be replaced or rebuilt. Just to be safe, remove the switch and test with voltage needle to see if the problems here. i suspect total motor failure.
Mar 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Sebo Airbelt K1 Electrical Problem
Remove the belt or seal that goes around it, there are some clips to take out, then it will separate.
Mar 03, 2008 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Sebo Air Belt C3.1 Bagged Canister Vacuum Logo
571 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
