Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
VLZ3U to Windows XP
How do I connect VLZ3U to Windows XP? Computer is not detecting
  • Anonymous Jul 06, 2008
    my WinXP Notebook doesn't detect the webcam ! Thk's for Help ! Need an USB Driver. Where i can download it ?
  • sheikh_alam4 Jul 17, 2008
    my sharp viewcam model no VL-E650U CAN NOT PLAYBACK IN COLOUR AND SOUND
I need to download usb driver
Posted on Mar 26, 2008
Im using v165w pen drive.when i connect to pc its not detecting the USB.i also tried with another pc also,the same problem occurs.i tried with both windows7 and windows XP..Wat can i do to solve the...
If two computers(and two different operating systems) arenot detecting the pen drive then most likely there is something wrong with thatpen drive and it needs replaced.
In Windows 7 you can check the following.
Plug the pen drive into an available USB port.
Click the Windows Orb(Start menu in XP). Right-click on "Computer"(My Computer in XP) thenleft-click "Manage". If "Computer" does not exist in the "Start" menuthen it should be on the desktop.
In the left pane click "Disk Management".
In the right pane, the first column will show you the drives currentlyinstalled(C:, D:, E:, etc). C: is typically the drive your operating system isinstalled on. To check what drive is what, just click the Windows Orb(Startmenu in XP) then click "Computer"(My Computer in XP). If you see the same driveletters under "Computer" that you see in Disk Management then the pen drive isnot being detected. Do you hear any sounds coming from Windows when you plug inthe pen drive? If you have a different pen drive is that one beingdetected? Are other USB devices detected when plugged into thecomputer?
Mar 07, 2011 | Dell Computers & Internet
Cant access wireless network
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
My PC (windows XP) doesn't detect Sansa e250 MP3 player
Turn the player off before you plug it in and if it doesn't find it then turn it on while plug in.
Jul 30, 2009 | SanDisk Sansa e250 MP3 Player
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
Hi, i am unable to install windows XP in pavilion dv6500 laptop. XP set up is not detecting the hard disk at all can you help me ?
Some copys of windows XP can not detect a SATA hard drive what you need to do is get hold of a later dvd copy of XP only the lastist dvd copys of XP are setup to detect SATA hard drives. It has to be a DVD copy as the CD copys do not detect SATA drives. Find some one with a new computer with SATA drives that has windows XP installed on it and try there copy of XP on your computer. Hopes this helps.
Jan 31, 2009 | HP Pavilion DV6500T Notebook
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Windows XP Does not Detect new USB Device
Microsoft has a helpful article in their Knowledge Database discussing how to fix this problem. http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314634
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
201 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
