Question about Canon PIXMA iP3000 InkJet Photo Printer
Paper transport is failing
I have also a problem with the paper feed. With plain paper there is no problem but with photo paper 180 gr. the transport is failing. Then I have to pull the paper out of the printer and try it again. Sometimes the print is o.k. after 3 efforts (My English is not very good so I find it difficult to explain.) I think that paper of 180 gr. is too thick voor the printer.
  • 749 Answers
You need to clean the paper feeder to remove a film of dirt that is causing the problem, also bend the thick paper on the edge of where the portion is inserted to ease the stress of taking the paper in... Lubricate the gears and traction mechanisms of the paper feeder to function properly and to last longer...
Hope this Fixya the problem... Goodluck
Posted on Feb 06, 2008
Help my hp envy 5530 printer is printing a4 pictures at funny angles. It is fine with plain paper it is just with the a4 photo paper.
Photo paper is heavier gauge and this may be showing a problem with the transport or pickup rollers and these may need cleaning.
Try the procedures listed here:
HP Video Gallery
Feb 03, 2015 | HP Office Equipment & Supplies
Paper transport works not properly, 3 flashes orange LED
First make sure the printers well connected and the power supply properly plugged.
  • Remove any previously loaded paper.
  • Check out the printers Auto sheet feeder/front feeder for any paper jams and remove manually any visible stuck papers.
  • Turn the printer off and on.This also helps in automatically removing any stuck papers that may not be manually removed.
  • Make sure there is no foreign objects in the Auto sheet feeder.
  • Make sure you load a fair amount of plain papers in the feeder,that is,reduce by half the amount you feed into the feeder.
  • In case the printers rear cover had been removed,fit it properly by pressing it firmly until it fully fits into the rear of the printer.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
Plain paper feeds no problem but photo glossy paper wont feed! (epson 830)
Hi
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Jul 15, 2011 | Epson Stylus Photo 830 InkJet Printer
The photopaper tray goes in, but the printer feed cant grab the paper. it is the correct direction, so i don't know whats going on.
Sometimes the printer does not feed the paper because it is too thick. Try to check the GSM of the photo paper, it should be 180 or 235.
Jun 27, 2011 | Office Equipment & Supplies
IT WILL NOT PULL THE PAPER INTO THE PRINTER
Feed guide roller worn, or not making contact with paper in the path, or failed microswitch that detects the paper and initiates the paper transport process
Feb 10, 2011 | Canon Pixma iP6000D InkJet Photo Printer
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
I can print on plain paper but when I use photo paper it tells me there is a JAM although the paper is barely in the printer.
Do not mix photo paper in the feed with any other type paper. Also, when you attempt to print, specify what type of paper you will be using to print pictures. Plain paper usually prints with no problems.
Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Is there a way to feed photos through the feeder without getting stuck for the Brother 780N? Adapter, different direction, etc.
There's no good way to feed photos on the Brother. It's designed for plain bond paper and doesn't do well on photos at all.
Jul 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
Paper feed not feeding properly
There is a gray rubber pad on the upper half of the feeder.
Take the white piece off and turn the pad 180 degrees.
Aug 28, 2008 | Samsung SF-560 Plain Paper Laser Fax
Canon PIXMA iP3000 InkJet Photo Printer Logo
69 people viewed this question
old marine
old marine
