Overflowing washing machine
My Samsung Hand Wash SW70A1P top loader won't stop filling with water. The valve where the water enters is fine. How do I fix this?
  • Wezzy Feb 08, 2008
    Thanks d-mac! Unfortunately my problem is definitely the pressure switch so I'm going to have to spend some money...
  • Anonymous Mar 12, 2014
    Where can i obtain a samsung fuzzy top loader washing machine rossby5 manual. Am I able to get teh maunal online?
  • 46 Answers
Check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
My defy top loader washing machine just overflow, the water enters without the machine been switched on and water does not stop entering even if I spin it
Could be a faulty fill valve. The inlet water pressure may be too high, making it necessary to turn off the water supply between wash sessions.
Jun 25, 2016 | Washing Machines
My Bosch classixx washing machine is overflowing
Bad water pressure switch or bad water inlet valve? does it have or leak water in the tub when not in use? ( inlet valve) sometimes the pressure switch tube has a hole or blockage in it and will not have the pressure needed to open diaphram and go into wash cycle and it may overflow
Mar 09, 2015 | Bosch Washing Machines
How do I stop the front loader (washer/dryer from flooding my rv?
If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
If the pressure switch is fine, check the water inlet valve for continuity on the solenoid coil by removing the top cover of the machine.
Sep 14, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
I have an old maytag model #LA712 top loader. Recently it has started overflowing not stopping when it's filling. This does not happen everytime and it does not leak any other times but when it does what a...
Usually this is caused by the water inlet valve sticking in the open position. If you can catch the washer while it's overflowing, unplug the washer. If the water stops, then the problem is most likely a pressure switch or pressure hose. If the water does not stop, it is most likely the water inlet valve.
May 25, 2010 | Maytag Washing Machines
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water flow into machine dribbling - Fisher and Paykel GW712 (AU)
The first thing that needs to be done is to disconnect the fill hoses from the back of the machine. Once disconnected, look at the inlet valve screens and check for blockage, if clear, open the water valves and check for water flow through hoses, if not clear, clean screens at fill valve, reconnect hoses & check for operation. If the problem remains, then the problem is with the machines fill valve & it would need to be replaced
Apr 30, 2009 | Washing Machines
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Washing Machines Logo
640 people viewed this question
Top Washing Machines Experts
