Question about Haier HLP21E Top Load Washer
No Drainage Stoppage?
Recently purchased the HLP21E.
Looks great. Just would love to be able to do a load of laundry. Followed the instructions. Have it set up right, however, the washer does not retain any water, from start it continuously drains, and never has any water in it to wash, and again goes to the stage of filling the washer wasting tons of water! Is there a quick fix for this? Dont' need an enormous water bill. The point of this was for convenience and the lack of having to dish out quarters weekly, now will I be dishing out Franklins for the water bill?
  • Anonymous Dec 08, 2008
    as soon as i start the water to fill mine, the water starts draining right out.
  • 291 Answers
The drain hose has to be higher than the full water tub level or it will keep draining out make sure your hose is high enough
Posted on Feb 07, 2008
Why will Haier HLP21E drain following wash cycle, but not drain following rinse cycle/before spin cycle?
Hello Michael;
My name is Peter. I am a retired field service appliance technician.
It sounds like your system just needs a good cleaning. Soap film will build up on the draining system components. You need to clean your float and insure it moves freely and makes contact with the float switch which turns on the pump. You may also need to disassemble your pump for cleaning.
There are products available for cleaning clothes washers, but these need to be used on a regular bases. I do not think they can clean enough to solve your current problem. Use after you have cleaned.
Dec 03, 2014 | Haier HLP21E Top Load Washer
Getting a E04 error code
According to siemens website Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens WFXD5200UC Front Load Washer
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
The washer has a very bad odor. I have tried using different soaps, but it still smells bad. The clothes smell "flat"----no odor----but the laundry room is getting to smell harsh. There is nowater outside...
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Haier HLP21E 6.6-Lb How do I remove lint filter?
You grab the plastic top and bottom of the filter and kind of pinch it so it pops out.  It's held in by small pegs on both ends.
Jan 13, 2009 | Haier HLP21E Top Load Washer
Front load wash smells moldy
They offer some great products on smellywasher.com. Also, if you keep the dispenser door open about a quarter of the way when not using the machine, this tends to help as well.
Oct 21, 2008 | Washing Machines
Water won't fill the machine
Do not remove that piece. It is needed.
Jan 22, 2008 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load Washer Logo
180 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
