SAMSUNG B1215J WASHING MASHINE (front loader )
I have had this washing machine for about 6 months but didn't start using it until last week.I noticed that water keeps flowing into it even when its powered off.I always have to drain it before using it because it gets filled with water.
I would appreciate your assistance.
I need eng manul forwashing masine serial no 14535dap500531e
Posted on Feb 15, 2008
Water flowing into machine when it is off [ie no power]
normally indicates faulty water inlet valve inside machine
if it is still under warrenty get machine manufactures engineers
to call to repair it where water hoses are connected to back of machine that is where inlet valves are inside machine
if not under warrenty disconnect from power turn water
to machine unscrew fill hoses take lid off you will see valves on
normally right hand side if not sure which valve it is replace both
ex engineer [must disconnect from power and water]
Posted on Feb 06, 2008
i don't think the problem has something to do with the 6 months delay in using it, right now i think there might be 2 possibilities
1. now that you have just started using it,there might be a mistake in the procedure you follow, because washing machines have options of single ring or double ring, you might be taking out the cloths before the completion of the process, so go through the manual to figure it out.
2. Or if there is no mistake in the procedure, then there must be a problem in the programing of the machine. It might have been mis-programed to fill in water after the whole process, if that is the case take it to the dealer to get it right.
Washing machine will not start, only get two red flashing lights, what could be the problem ?
Sounds like something toasted on the control panel
Better call certified appliance repairman
Oct 08, 2014 | Russell Hobbs RH1042 Frontload Washing...
Samsung front load washer does nt empty water does nor run
hi! I've faced the similar problem and procleaning the trap was a solution. Meanwhile you can learn Samsung washing mashine instructions, for example here and try to find the necessary information. Samsung Washing machine user guides and owners manual
Mar 03, 2014 | Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
I rented a home and ive got a washing mashine(simpson esprit 450),so my poblem is how to use it.i have to put washing powder first? and where to put?then what?....pls help
Hi just read your posting.Is your machine the TOP LOADER model or the FRONT LOADER model.Please reply with additional information and I can help you with instructions on how to use the machine.
Aug 01, 2010 | Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Aug 13, 2008 | Washing Machines
Kaiser otsein
did it come with a use and care guide
Mar 30, 2008 | Washing Machines
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
