Innovera Wireless Presenter
I purchased this device to control powerpoint and other programs during live presentations in front of large groups, so as not to be tied to my computer. When I went to set it up, I did as requested (screen prompted me to hit the key just beside the SHIFT button on the LEFT side of the keyboard. The message I was received was that it wouldn't work because it's not an external keyboard. There was no other option to set up the device using the keyboard that goes with my laptop, which of course is the computer/keyboard I travel with to do presentations. Any clue? I bought this in December and I've not been able to get it to work!
I don't see this product listed in your product category, but I have the product and written on the front is: Wireless Presenter. Works with a USB key to move slides ahead and back. Any ideas/
maggie Dugan
SOURCE: wireless presenter dont work
Did you press the right button on the remote? To 'sync' the sender and reciever, and thus start it working, you've got to turn the handheld OVER and press the mysterious little button in the middle at the same time as the button on the USB stick. Also helps if you have them right next to each other when you do this. You should see a green light on the USB stick, and the laser pointer should work on the handpiece if the batteries are good. Mine was working fine for heaps of presentations then suddenly stopped one day and only the laser pointer would work. Batteries were fine, as is the common story. Then I found out that if you turn the presenter over and press the 'reset' button in the middle simultaneously with the USB reciever stick, the two 'sync' and it starts working again, hey presto. I've always found it a breeze to use once I figured this out. If that doesn't work take it back, you need a new one.
Posted on Aug 21, 2007
daverh
  • 117 Answers
SOURCE: KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Posted on Oct 15, 2007
tat4u
  • 520 Answers
SOURCE: unable to connect to my wireless system with hp pavilion dv6353us
install software for ur plug in wireless then plug in ur wireless ...not until this point will system find and install....then get online and find driver for ur internal wireless ...download and install.....when u remove ur external and restart system will recognise internal as only wireless and configure ...if still have problem ....and ur problem wont be wireless Itll be getting online....then u need to config wireless differently.
let me know
Posted on Mar 08, 2008
  • 349 Answers
SOURCE: Targus Presenter Issue
It sounds to me like a warranty problem,ring the manufacturer or supplier they should be able to help you out to fault find the problem, or replace or repair it .
good luck
Terry
Posted on Mar 19, 2008
ginko
  • 19396 Answers
SOURCE: KVM converter
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
Posted on Apr 10, 2008
August LP102R presenter will not work
You obviously need a driver. Where did you get the presenter?
Apr 11, 2014 | August LP102R Wireless Presenter with Red...
Ano ang power point
PowerPoint is a presentation program developed by Microsoft. It is included in the standard Office suite along with Microsoft Word and Excel. The software allows users to create anything from basic slide shows to complex presentations.
PowerPoint is often used to create business presentations, but can also be used for educational or informal purposes. The presentations are comprised of slides, which may contain text, images, and other media, such as audio clips and movies. Sound effects and animated transitions can also be included to add extra appeal to the presentation. However, overusing sound effects and transitions will probably do more to annoy your audience than draw their attention. (Yes, we have all heard the car screeching noise enough times for one lifetime.)
Most PowerPoint presentations are created from a template, which includes a background color or image, a standard font, and a choice of several slide layouts. Changes to the template can be saved to a "master slide," which stores the main slide theme used in the presentation. When changes are made to the master slide, such as choosing a new background image, the changes are propagated to all the other slides. This keeps a uniform look among all the slides in the presentation.
When presenting a PowerPoint presentation, the presenter may choose to have the slides change at preset intervals or may decide to control the flow manually. This can be done using the mouse, keyboard, or a remote control. The flow of the presentation can be further customized by having slides load completely or one bullet at a time. For example, if the presenter has several bullet points on a page, he might have individual points appear when he clicks the mouse. This allows more interactivity with the audience and brings greater focus to each point.
PowerPoint presentations can be created and viewed using Microsoft PowerPoint. They can also be imported and exported with Apple Keynote, Apple's presentation program for the Macintosh platform. Since most people prefer not to watch presentations on a laptop, PowerPoint presentations are often displayed using a projector. Therefore, if you are preparing a PowerPoint presentation for a room full of people, just make sure you have the correct video adapter.
Jul 12, 2011 | Microsoft Computers & Internet
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Targuss Wireless presenter not recognized
The first thing that I would advise you to do is,
Make sure you are connecting it to your system through a USB 2.0 Port, and not 1.0 USB Port.
Next, uninstall the Wireless presenter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wireless presenter).
After this, ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you don't know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 24, 2009 | Targus wireless presenter with laser...
I wanted to use power point on my tosbhiba lap top ,with the benq projector.i hooked it up and my montor went black but i can still the program on the projector screen what now?
You were succesful
Now run the powerpoint presentation as you would on a normal screen.
Most laptops also have the ability to run both displays at once and you may want to check out that ability too if you are having problems operating on a large display.
I usually use a wireless laser pointer presenter that operates as a mouse so that I can wander while using presentations.
Sep 21, 2009 | Computers & Internet
I forget how to connect my targus presenter to the usb device. What sequence do I push the connect buttons?
To Reconnect the Device and the Receiver :
Position the Power Switch to “Presenter” mode to turn on the presenter.
1 This presenter is a plug and play device and should work once the USB receiver is connected to and recognised by the computer. If the device is not working or you have recently replaced the batteries, you can try to reset the ID code between the receiver and the remote. To do this, do the following:
2 Once the computer has recognised the device. Press the
connection button on the receiver.
3. After the connection button is pressed on the receiver, press the
connection button on the back side of the presenter.
The devices are paired and ready to use.
Or check from page 5 on the USER GUIDE
Dec 17, 2008 | Targus (AMP0205USZ) Remote Control
Targus Multimedia Wireless Presenter
Reload the drivers for this keyboard. Make sure that the drivers are for the OS (operating system) that you have.
Mar 27, 2008 | Computers & Internet
Microsoft Presenter 3000 does not work
My 3000 has a green light but it only flashes to indicate the sync period during which time you should press the button on the back of the presenter. The presenter works well and to date I have had no problems.
Nov 02, 2007 | Microsoft Presenter 3000 Mouse
Computers & Internet Logo
144 people viewed this question
Alun Cox
David Payne
David Payne
