Question about Lenovo 3000 C200 Notebook
Digital camera sd card stuck in laptop
When I inserted the sd memory card into the sd card reader (left hand side, towards the front, below the crad reader) it kept going in and when I attempted to use twissers it just went in further.
How do I retrieve SD card?
  • Anonymous Mar 18, 2014
    Cannot figure out how to remove sd card. Installed before going to settings
  • 749 Answers
Hi...
Remember that the SD card has a little slot at the center we'll use that to retrieve the card. First, find a "medium safety pin" and straightened it and on the sharp edge, use a plier to make a little hook... Use that to pull it out....
Use an extended card holder to insert the SD card because the design is for the mini stick SD card...
Goodluck... happy Fixya...
Posted on Feb 06, 2008
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
How do i upload from a fuji camera memory card
If your Fuji Camera uses an SD card then you can insert the SD card on the SD Card reader on the front left side of your laptop.
Otherwise, plug your camera to your PC with USB cable.
I assume your Fuji camera takes SD card and USB.
Oct 12, 2014 | HP HDX16-1160US PC Notebook
I have Gateway Model MS2285 Laptop. Where do I insert my SD card to copy pictures from my camera?
As far as I can tell, it should be a thin slot on the side of the laptop, left hand side, towards the front.
Jun 03, 2011 | Gateway Computers & Internet
Card cannot be formatted
Make sure the write protect lock is off on the SD card itself. To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Apr 12, 2010 | Kodak EasyShare C643 Digital Camera
Where do i insert a memory card into a gateway md2614 laptop
It depends what type of memory card you are referring to.
USB memory will plug into the USB ports on the left side of the laptop.
If you are using a Memory Sick, Memory Stick Pro, Mini Secure Digital, MultiMediaCard, RS_MultiMediaCard, Secure Digital (SD), or xD-Picture card they will go into the memory card reader on the left side of the laptop about 2 inches from the front of the machine. ** NOTE: this is the bottom slot.
If you are using a Type 54 ExpressCard it will also go in on the lfetside but this slot will be above the Memory card reader slot mentioned above.
Good Luck! :-)
Dec 20, 2009 | Gateway MD2614u Notebook
How do i unlock my sd card
There is a slider on the left hand side of an SD card which sets the card to Locked (lower position) or Unlocked (higher position - i.e. towards the top of the SD card). The first step is to check the position of this slider.
Note that the position of the slider does not affect the SD card in any way - it trips a switch inside the camera (or other SD reader). The slider MUST be in the upper position or the camera will say Card Locked - so if the slider has fallen off (they are very fragile!) the camera will assume it is in the Locked position.
Jul 19, 2009 | Praktica SlimPix Digital Camera
Display says card not initialized when a new xd picture card is inserted in the fuji fine pix A340 how do i initialize or format the card
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/ you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Jul 08, 2009 | Fuji FinePix A340 Digital Camera
Where do i insert my memory card on my hp business notebook laptop.
The Where its usually found in the front of the laptop or on the right side, its usually marked SD reader, The How is: you insert the camera card with the copper connection facing down. some of the older model laptops only come with SD readers for cell phones and video cameras not like now that they come with every type of card readers
May 20, 2009 | HP Pavilion zd8000 Notebook
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Lenovo 3000 C200 Notebook Logo
696 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
