Question about Teac HD10U5/KIT 5 GB IDE Hard Drive
Hard disk how is the structure of a had drive after formatting.
  • 449 Answers
The structure of a hard drive after formatting can not be viewed after formatting unless microsoft as prepared a software for verifying hard disk.you can visit google about that and i can still paste the answer later in the evening
Posted on Feb 06, 2008
My 1T external HDD won't format and reads as raw
I am assuming (because you did not tell me) that you are running a version of Windows. You need to open help and support and search under drive management. The drive is showing as raw because you have not yet created a basic volume or any partition structure.
Apr 02, 2015 | Computers & Internet
Reformat partition hard drive
To return your HD to the factory settings do a full system recovery using the recovery disks (CD or DVDs) you made when you first had the computer. This will return the whole computer to its as-shipped state: you will lose all your data and any software that you have installed. This will retain/re-install the original partition structure on your hard disk. To do this process you may also use the recovery partition on the hard disk.
To completely reformat the hard disk, in which case you will lose everything on it
press the start button at the bottom left of screen,
R-click on computer, and select manage. The computer management window will open. From the left pane click on disk management under 'storage'. A new pane will open, with information on the different disks in your computer. Select the disk on which the partition to be formatted is located. R-click on the partition to be formatted, and choose format, and ten work through the format wizard. (see http://windows.microsoft.com/en-us/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7)
When you R-click on the partition other options will appear will appear as well as format, choose the appropriate option to create a new partition, merge, etc, By successively working your working your way through the partitions you may format/merge some while retaining others.
18.July.2014
Jul 11, 2014 | HEWLETT-PACKARD Computers & Internet
Pc recognizes the device in device manager list but not in my computer window
You could check Computer Management > Disk Management. It should show up. If it does not a have drive letter it is not recognizing the format structure and sees it as new. I would test on a different system before committing to any changes.
Aug 27, 2012 | MicroNet Technology Fantom Green drive 15...
Western Digital External USB 3.0 1 TB Hard Drive: The disk is inaccessible. The file structure is corrupted and unreadable
There is companies that make data recovery, you could try them, there is also some for private use, but they are not that good. But those companies will pay a lot, if you have a good home insurance you could try them to pay recovery.
Depends how much you appreciate the information on hard disk.
Jul 23, 2012 | Computers & Internet
Is not accessible , the disk structure is corrupted and unreadableWhat's your problem?
The hard disk could be faulty.
Try formatting the external hard drive again.
If this does not work then most likely the hard drive is faulty and needs to be replaced.
NOTE you will not be able to recover your data when you format the hard drive.
May 23, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My 500 GB store jet Transcend USB hard drive not detected. when sometime its detect, message is flowing " Hard disk is not formatted. do you want format now? " please help me what i do ?
You will need to format the disk so the file structure can be read by your operating system. Formating the disk will wipe all data from the disk but will only need to be done once.
Mar 01, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
While Booting My Desk top Precision 360 of DELL.I have SeagateST373453LW SCSI Hard disk.At start up disk is recognised but capacity is not. If I am Verifying or Formatting my drive throug Ctrl/A for...
There are a couple of things here..
First I am going to assume this is the LSI card that came with the Dell.
1. Since it is a RAID card, the formatting you are seeing may be referring to the RAID structure. Does the configuration utility ask you what format to be make the drive (i.e FAT, FAT32, NTFS, etc.)? If not, it may be doing that type of format. Also, you did not mention a second drive so the controller may be getting confused. If you have a boot disk/cd rom for the operating system you wish to load, try booting the disk. In a lot of cases, the operating system will format the drive to a particular format.
2. Make sure your controller and drive are not on the same channel. A lot of cards auto assign this but since the Dell has a 2003 date, its worth checking.
3. I've seen drives detected before but not usable. It had to do with the SCSI cable and termination. If this is the SCSI card and hard drive that came with the computer, this may not be an issue (assuming it worked previously).
Nov 02, 2009 | Dell Precision 360 PC Desktop
Hd hard error
  • HI
  • TO TEST THE HARD DRIVE ON THE COMPUTER
  • Run the Windows Check Disk utility. This utility will check and repair system file errors (logical structure), and examine the physical structure (the integrity of the disk surface) as well. Close all applications, browsers, and utilities.Open My ComputerRight-click your hard drive (C:)Click Properties, then click Tools TabUnder Error-Checking, click Check NowClick check box for "Automatically fix file system errors"Click check box for "Scan for and attempt recovery of bad sectors"Click Start to run the utility
  • Download and run the freeware diagnostic tool "HD Tune". This terrific tool will run a complete benchmark analysis of your hard drive, check for structural errors, examine overall health issues item by item, and more.
  • Download and run the freeware diagnostic scanning tool "Emsa DiskCheck". This tool is a dual purpose utility for disk checking (pre-scan and full disk reading) and benchmarking.
  • THANK YOU
  • Sep 13, 2009 | Dell Latitude D600 Notebook
    Cannot access disk information
    Yes we can save you :D
    First off though, with the combination of a virus and a formatted drive I will only recommend that you send it to a pro. Too many things that could go wrong and any of the files that are currently recoverable could be destroyed trying some of the usual testing methods.
    Comment back with your region and city and I will find an appropriate pro for you to contact.
    Chris
    May 28, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
    My external hard drive is corrupt, i want my data back.
    Dear,
    Data can be recover but the drive must be accessible by OS. As you write windows vista says drive is not accessible and that the disk structure is corrupted and unreadable.Do one thing try the same drive at another PC. If it run on that PC copy the data to that PC. Now format the drive and paste the same data back to your drive. But, if same thing happend then there are chances of fault in the driveand for this you shuld visit to the service cetre but, they are not responsible for the data.
    Thanks & regards,
    Rakesh Kumar
    Apr 05, 2009 | Buffalo Technology 1TB DriveStation...
    Teac HD10U5/KIT 5 GB IDE Hard Drive Logo
    76 people viewed this question
    Top Teac Computers & Internet Experts
    Starnley Johnwells
    Starnley Johnwells
    k24674
    Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
