RCA 52 I'm looking at buying a used RCA 52" Projection tv. Its about 3.5 to 4 yrs old. Im not sure of the moedl # but it is silver in color with the speaker cover below is a darker gray. The owner sent me a picture of the tv and explained the problem. When there is words on screen such as weather channel, some letter might be missing of a word. And the word is in an arc or curve. She said they called and the tv repair shop said the convergance needed to be reset and it would cost $200 to fix. I'm wanting to know if this is true and if this is what the problem sounds like? Also, I'm trying to get a parger tv for a cheaper price. I've found a lot of these tvs with the same problem for cheap. Is it a good idea to buy a tv needing something like this? Or could it end up needing more to fix than the tv is worth? Thanks for a response!!!
    President:
  • 4,402 Answers
Common for these sets to have bad convergence amp ic
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Feb 06, 2008
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
I got a 52 in rca hdtv projection tv and it went all 3d looking. is it able 2 be fixed or were they recaled i only have had it 2 yrs. this christmas would have been3 yrs
Ur convergence it dead,know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | RCA HD52W59 HDTV Projection Television
Im having a issue with my RCA 52 inch HD tv. It is like watching in 3D everything is in 3 colors
Bad fuse FL231 it does not look like a fuse But it is ! it will be on your deflection board first bottom board to the left on right side of FBT flyback transfomer thier is 3 in a roll small brown rectrangler looking caps but they are fuses it will be the one in the middle call Mats Electronics 1-800-628-1118 for fuse.
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen image
Go to menu then setup look for convergence if it is not Listed then you have an open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a roll small brown rectrangler looking caps but they are fuses the one in the middle is BAD.This is a $ 225.00 repair job.if done by TV shop.
Aug 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Older RCA Projection screen, Blue picture!
take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Sep 10, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 inch projection looks like 3-d movie
Open up the back, the convergence ICs are large and attached to a heat sink. They should be marked STKxxx. In most cases, replacing the ICs is enough. Sometimes the feeder resistor fails because of too much current draw. Change the ICs before looking for more parts. Also, try resoldering the ICs. Bad connections can cause this problem as well.
Dan
Apr 09, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
