How much memory do my laptop need to run XP system? My Laptop (Compaq Presario 2200series ,2205AL model lcd Display started showing white line as row
  • 749 Answers
Hello
To run XP at least you should have a 256MB or higher
128MB is Minimum but too slow
It seems that the LCD has a permanent problem... that area had already leaked, no remedy. Find an LCD that matches your Laptop and replace the LCD.
Good luck... Fixya me on this info... Thanks
Posted on Feb 06, 2008
My Compaq presario CQ42 has a white-red thin line at the right corner of the screen. Is it a problem to use the laptop with it before I fix it.
@tharindupedu
If you see a Vertical/Horizontal colored lines on your LCD, that means either the Video Card, LCD, or the LCD Flex cable (this is the cable that connects your motherboard to your LCD screen) are going bad and needs replacement. You can still use your laptop though but I strongly recommend having it fixed ASAP before it gets worse. You're still under warranty, call HP/Compaq at 1-800-652-6672.
Good luck.
Sep 07, 2011 | Compaq Presario M2000 Notebook
I have a problem.that is, whe i switch on my laptop with a hibarnate system that time display show white,after booting display back to windows.when i shutdown it,after that when again i on it.that time...
is this a 100% hibernate only failure? questions?
tell what the PC does good and bad, then we can answer.
NO OS stated, XP ?
first off for hibernate to work the following must be ok.
1: XP? not infected as all are.
2: all HP drivers that came with it new, still present and loaded.
it came with XP or VISTA
see that here. load all drivers, and it can work.
Id avoid hibernate totally, on such and old PC< unless
reloading everything from scratch, is ok. for you. I would.
Use the F11 key at power one to reload windows.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-v6700-notebook-pc-series/3629671/model/3651450
Aug 20, 2017 | HP Compaq Presario V6700TX Notebook
Display adapters
You need to download the video drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jul 30, 2010 | HP Compaq Presario V2000 Notebook
No Sound on Start-up, Compaq presario c300
sound when the start up the Compaq laptop is disabled ...
it is depend on the operating system of the laptop. if you use operating system of the windows of the trial version or the pirated windows xp then it is comes.You purchase the original version of the windows xp or use other windows as vista ,premium..etc.
Apr 09, 2010 | HP 435768-001 - Compaq Presario C300...
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
Hi there. i got a problem with my laptop lcd display. at the bottom of the screen is a line, usually white blurry lines. sometimes this line shows a portion of the upper screen. what's the problem? is it...
Hi Rhyecho,
Your problem could be one of several things...
1: Go to Compaq.com or HP.com (They're one in the same) the video/display drivers for you're particular model and operating system and reinstall them. If that doesn't solve it....
2: Hook the laptop to a standard monitor (desktop) via the blue VGA out in the rear of you're machine.
Once you turn the laptop back on see if you get the same symptoms on the other display, if you don't, in all likelihood you've got an LCD problem. If you do get the same symptom its probably related to the video chip (or other problems on the board).
Additionally, If you still get the line on the other monitor you could try this, Depending upon how brave and or experienced you are, on rare occasions the cable leading from the motherboard to the monitor may not be seated properly and could be causing the problem. But you'll have to remove to keyboard to find out. (The screws to do this may or may not be marked with keyboard icons on the underside of you're machine).
Unfortunately, It sounds like you're problem is probably on the board though.
Either way good luck.
Jul 18, 2009 | Compaq Computers & Internet
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 6000 Monitor Problem
sounds like your lcd screen is on it's last legs...time for a replacement..
Jun 01, 2008 | HP Compaq Presario V6000T Notebook
LCD Display
This service manual will show you how to disassemble your laptop to replace the LCD screen.
The procedure starts on page 114.
http://h10032.www1.hp.com/ctg/Manual/c00374392.pdf
Please let me know how you make out..
thanks.
Jan 29, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
