Question about Vacuums
Shop vac Wet/Dry Vacuum 2.0 manual instuctions
  • Anonymous Nov 25, 2008
    need manual
How do you make a Shopvac wet/dry vacuum blow out air
Posted on Feb 08, 2008
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
New vac no instuction manual . i need to vaccumn
No you do not need the filter to pick up glass. If you are vacuuming up dust/dirt then use the filter.
Jan 22, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
533 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
