Broken Magnavox 5 disc changer
It makes a really loud and continuous clicking sound when the door is opened. It will not play the CD's and only reads "ERROR". I took it apart and I see what looks like some sort of capaciter with an arm that turns against a wheel or gear. Both are turning continuously while the door is open. This is located directly under the bottom circuit board. It is an older player. I'v had it for about 16 years, but it is the best one I have ever had.
The Model # is CDC796 1701. The serial # is 23304799.
Thank you for your help.
  • 983 Answers
Old is always gold... just follow some tips as i say... open the player with the door ejected clean the lens wit the dry cloth and clean the dust particles in it especially near the rubber belt connected to the dc motor... after that try to play cds it will play...
Posted on Feb 06, 2008
My 2001 RCA 5 CD Disc Player won't open and makes a continuous motor sound. I thought a cd was stuck, I took the top cover off and removed the offending disk. However the problem remains. The player
Five disc players often develop indexing problems. While you have the top cover off, first read and heed the laser warning then you can watch the mechanism spin around merrily trying in vain to find a home position. You also can insert a disc in a random position (say number 1) and watch it be unable to locate the disc and display the location correctly.
Nov 21, 2013 | RCA RP8070D 5-Disc CD Changer Disc Direct...
The cd door is stuck as if a cd is out of place. Won't open enough to see the problem.
Before, when trying to see the problem, I clicked "skip" to see if it would go through all the discs. It did, but still wouldn't open the door. Later, I clicked "play" each time, then "skip", and after going through all 5 discs, the door opened. Go figure.
Dec 19, 2009 | RCA 100-Watt Stereo System With 5-CD...
When i press cd on my radio it constantly says reading on the screen but no sound is coming out.i have a classic beetle and it needs music
The problem normally is to the reading head. You have to open the player find the head and clean it with a cotton stick very gently. Then try to listen a cd. If it works it's ok, or else your head is broken and you have to replace it thing that I am not suggesting because of the high cost of the head.
Oct 07, 2009 | Kenwood KDC-C667 6-Disc CD Changer
Increasing static and complete sound loss
hello you mean buzzing,humming cause is a high missing broken ground and it needs service by electronic shop............make shure is not missing any wire that must be connected or undervlotage working............saludos
Jan 08, 2009 | Denon DCM-280 5-Disc CD Changer
5 cd changer on a peugeot 307 has all 5 lights flash but will not play
cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Dec 14, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Player won't read cd's keeps opening door
This model has a belt used for loading the cd mech, after you push play if the belt is slipping or gone,the door will open, if you take the cabinet off eith power off and traopen, look at cd mech you see a belt, it may be loose or gone
Oct 25, 2008 | Yamaha CDC-565 5-Disc CD Changer
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
YAMAHA CD PLAYER WON'T PLAY
GG  My kids had a PlayStation 2 that did this and so did my AIWA 3 CD player.  The solution for the PlayStation was to remove the cover use alcohol and clean the lens of the laser reader.  They get dust on them and simply cannot read.  The AIWA required replacement of the laser which cost almost as much as the unit and didn't last 6 months.
Oct 17, 2007 | Yamaha CDC-565 5-Disc CD Changer
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
273 people viewed this question
 Grubhead
Grubhead
