Question about Photography
Canon FTB meter
I have not used by FTB for several years and now my daughterneeds to use it for a hi school photo class. The meter wasworking fine to start with but after removing old film from who knowshow long ago, the aperture needle will not move from the lower cornerwhen adjusting f-stops. I replaced the battery to make sure theproblem wasn't there and loaded fresh film. Still the apertureneedle doesn't move. I have tried with different lenses (to besure that i didn't have a damaged one) still no difference. What am I missing????
  • leov1957 Feb 06, 2008
    I checked that out and it seems ok. If i have the lens off and flip the mirror up should I be able to see an aperture grow or shrink as i move that lever?
I had the same problem with this camera, I bought a new battery, and the meter was not working. I took the battery out for 30 minutes, then I installed it. I then took the lens off, carefully lifted the mirror up and down on my own, and it began to work on its own.
Besides that, I didn't do anything else.
Posted on Oct 11, 2008
  • 667 Answers
The battery only powers the meter needle. The aperture match needle is controlled by the lever that is to the right of the mirror box. You can see it with the lens off while looking at the mount. It may be bent or damaged.
Posted on Feb 06, 2008
I have an old canon ftb and when looking thru view finder there is a red rectangle almost like a piece of tape stuck on bottom right corner. thanks for any help. See attached
Hi Dear!
http://www.baytan.org/prak/pdf/CanonFTb.pdf
Please check with page 21 on the manual. However, it looks like a loosen piece from penta prism supporting piece moves around. It won't give shutter functionality but it could cause metering problem sometime. It has some timing involve with disassemble, I won't recommend you to opening the camera unless you are ok with lose your camera broken. You should bring to your local repair shop.
Hope You Luck! A Professional Camera Clinic Guy!
Apr 07, 2015 | Canon Cameras
Canon EOS Rebel T2 - film loaded, but then wouldn't take a picture, the frame count was flashing on screen. What is the problem?
Hi. Open the camera back and pull the film further over towards the pick up spool, close the back and try again to take a photo, i had the same problem with an eos 650 and it always worked.Good luck.
Apr 15, 2014 | Canon EOS Rebel T2 with 28-90 lens 35mm...
When doing an outdoor shot backgroung comes up white, but when used indoors it comes out fine
it is ussually the truoble of some dig. camera,,,it is because the ribbon inside the lens is officially broken,,it require a well trained technician to fixed the problem....
Feb 22, 2012 | Canon PowerShot A450 Digital Camera
I have a Canon AE-1 SLR camera for my high school photo class and it was working fine but all of a sudden my film advance lever locked and now it wont take any pictures, does anyone know how to fix this?
This may not be the problem, but could it be that you've run out of film. The end of the film is attached to the 35mm film canister. When you run out of film it will prevent the advance level from moving.
Sep 02, 2010 | Canon EOS-AE-1 35mm SLR Camera
Hello I have a vintage FTb camera and would like to know what year it is by the serial number- can you point me in the right direction?
Canon began manufacturing the FTb in 1971. You can see the page for this model at Canon's Camera Museum. Its replacement was the FTb-N, which came out in 1973. I don't know if you can find exactly when your camera was made, but it's probably safe to assume that it was between 1971 and 1973.
May 27, 2010 | Canon Photography
I have a Canon FTb. mirror locked up.
I have an FTbn 35mm you're talking right?
On mine there's a tiny lever near the lens that when turned, it locks the mirror up for lenses that are too long.
If that doesn't work, you can buy my FTbn. ;)
cyress@my fairpoint.net
Dec 23, 2009 | Canon Cameras
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Shutter release button wont work! Help please, and fast.
skye-skye,
is the light meter working ? if not replace the batteries
Nov 16, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Canon A95 - Download freeze after several pics
Reset the camera settings back to default.. thats all it will be alright!
Mar 19, 2008 | Canon PowerShot A95 Digital Camera
Colour errors
I would try changing photo papers to see if that improves or worsens the balance.
The absorbtion rate of papers differs greatly which can influence colo(u)r saturation.
(My American grade-school teachers used to foam at the mouth when using the English lost 'u'.)
Jan 10, 2008 | Canon i9100 InkJet Photo Printer
Photography Logo
408 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
