Question about Dell Inspiron E1505 Notebook
Unable to conect to the network using Xp
I am using Xp ,unable to connect to network
    Guru:
  • 55 Answers
There might be lots of issues if u r not able to connedct to the internet......first check the connection from the wall socket to the tower .........if u r sing a dsl connection if u r usinfg a dial up check the connction from the wall socket to the modem ...............then if u r using a dsl connectio then go to safe mode with networking by tappinf F8 when ur system boots up........then try login in if u r able to log in then ithe issue might be with firewall or norton.....if u r using a norton......if not then click on start---run---type cmd-----then u will be able to see a black and white screen and then type ipconfig.......if the ip add is 169.....it is an automatically generated ip address if u get ip add starting with 192..then u might have the issue with the routewr remove the router and try connecting i.....if u get a valid ip as 10.98.55.56.....or something that does not start with 169 or 192 then ur isp is fine and u should be able to connect to internet .,,,,,even if u have a valid ip and if u r not able to connect to the internet then lower the security level ....and delete cokiees,,history and temp files it will connect.........................................but if u r using a dial up then u might have some error code if u have any error code go to google.com type in the error code u will get a resolution bcoz discussing an dial issue is very difficult to type in here ...............................even in dsl there is a huge troubleshooting steps i have typed in a small step if u r still not able to resolve the issue then shoot a mail at gunjansarkar@gmail.com.....iwill definetly look for a resolution...........
Posted on Feb 06, 2008
I'm unable to connect to my push2tv netgear box. I could connect fine with my Toshiba Sattelite (Best Buy Blue model). However, I'm unable to connect with a Toshiba Sattelite M645-S4070. It has Win 7...
Sounds like you have a firewall problem either with the Windows 7 built-in firewall or an anti-virus application firewall. Do you have an Anti Virus program installed?
Nov 24, 2010 | NetGear Push2TV TV Adapter for Intel...
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
When i unplug lap top lose enternet conection
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 23, 2010 | NetGear DG834 Router
Unable to conect wireless computer is saying cannot display the webpage
Check the configuration
Check if you have created a wireless network
If XP/Vista OS then connect the wireless connection
Try to check DMZ settings as well
If not change the wireless network name and channel and try with it
Jan 13, 2010 | NetGear WGR614 Wireless Router
Can not connect wireless network
Have you checked within Device Manager that both you Lan and Wireless drivers have installed correctly during your reinstall of Windows XP?
Sep 15, 2009 | Microsoft Wireless Network Adapter Xbox...
I have a acer aspire 5570Z, unable to connect online...
Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
If you are using your manufaturers software then try using windows xp (or vice versa)
Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
LAN not conecting
remove ur lan card and clean it and install it
Jan 21, 2009 | Acer 91.AB370.001 Network Adapter
Trouble connecting wireless
first thing to do is to dissable the ethernet connection in network connections on your notebook so as the ip address does not conflict.
assuming it's XP and assuming DHCP is enabled in the router settings, right click on your wireless conection in network connections, properties>TCP/IP line, highlight it and then click properties again, then ensure obtain an ip address automatically is ticked, apply and ok, close window.
If neccasary run the wireless network wizard in new connections in network connections.
Open internet explorer>tools>internet options>connections tab and ensure that 'never dial a connection' is ticked, ok and close IE.
Open IE and click refresh a few times.
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
Dell Inspiron E1505 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
