Question about Intel Motherboard
I hear a beeping sound from my motherboard
What must i do?
    Novelist:
  • 103 Answers
There's an error during POST. It's maybe the memory, video card, keyboard, and all other controlled devices. Reheat the mainboad if necessary.
Posted on Feb 06, 2008
Help my dell is not displaying but the front led is showing the power light on CPU but is not displaying on the monitor and i have used working RAM on the Computer but the problem is the same, kindly help...
If you do not hear a post beep sound, then you may have an issue with the motherboard and/or processor. I suggest you either take it in for repair or replace yourself
If you hear the post beep sound, then listen for the sequence of beeps. This should indicate what is wrong with the machine. Generally(Note: these may be different with motherboard and/or bios type).
  • sequential long beeps indicate RAM issues
  • 1 long followed by two short indicate a display adapter issue
Mar 23, 2015 | Dell (E210882) Motherboard
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Get a series of error sound and 2 beep sound at the end when turn on my hp pentium4 and the system refuse to come up. pls, what could be the problem. thankx
Anything MORE than ONE beep indicates that the motherboard has detected a problem:
* bad RAM
* RAM not correctly "seated" in its socket
* one of the fans powered by the motherboard (CPU, case) is not spinning, or is not spinning fast-enough
* bad video-card
EXACTLY what sequence of "sounds/beeps" you do hear?
Jul 30, 2010 | EliteGroup ECS 661FX-M Main Board Socket...
Hello, I recentily buy a GIGABYTE GA-EP45T-UD3LR motherboard, it workd great, but don't have the "beep" sound when boot, I test via software the internal speaker and it works, is this correct ?, I hear...
1 beep is the BIOS signaling all is well after testing components inside and attached to the pc. On newer motherboards it's heard only when you have something attached to the USB connectors . Do a simple test: boot with an connected USB device, like a running printer or an memory stick - you will hear the short beep as you were used to.
Apr 13, 2010 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
No display on boot motherboard e210882
does it has any beeping sound? if you hear any beeping sound check youre memory module or vga card, now to know the diff between the two is the beeping sound first if you hear a long beeping sound it means that a memory replacement is needed, second if you hear a short beep and has intervals you have a problem with vga card, now if your vga is built in try putting a vga card now it depends on the motherboard weather it has a agp or pci-e port, before you do this try checking youre power supply if it is working, hope this help
regards
Michael Ibot
Nov 19, 2009 | Dell (E210882) Motherboard
No signal from the motherboard to the LCD
First of all check whether u fixed the connections properly like RAM , Processor and Motherboard to the Cabinet. If u can hear any Beep Sounds at the start up it is easy to identify the problematic part. If u cant hear any of the beeps the problem may be with the display capacitor, change the display capacitor and the diode with a good chip level technician. The problem will be resolved.
Oct 15, 2009 | Intel Motherboard
My motherboard sound
THE BEEPING IS TRYING TO TELL YOU WHAT IS WRONG WITH THE COMMPUTER.
HOW MANY BEEPS AND WHAT TYPE OF SEQUENCE. ARE THE BEEPS SHORT, OR LONG, OR MIXED.
ROD
Mar 13, 2009 | ASUS Serverworks ServerSet III LE CUR-DLS...
3 beeps
3 beeps are mostly heared when memmory gone out of order, disslocated miss matched. you need to focus on memmory.
Oct 20, 2008 | Intel Desktop Board D845WN Motherboard
Intel Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
