Question about Canon PowerShot A450 Digital Camera
Canon powershot a540 black/web screen display
Hi, my camera works and all i mean i could take pics/videos but only through the included rca cable. And the display doesnt want to show any pics/videos that i took of. Instead it shows a blackish/purplish web or black screen. And everything else works (settings/buttons) but just the screen doesnt want to show anything. And i didnt drop it nor water get in it. pls advice
  • ygjeff21 Feb 11, 2008
    I have an A540. I noticed that it started to go blank but if I played around with the buttons it would spring to life again. A week later it went blank and never sprang back to life. I'm convinced it's a CCD image sensory problem that Canon has an advisory out for. The problem is that the A540 is not in that advisory. I'm stuck having to plead with Canon to fix my camera and convince them I did nothing to cause the problem. They also want to give people an inferior refurbished model at a low cost instead of correcting the problem in the defective camera.
  • Anonymous Jul 30, 2008
    So i turn on my camera and its all black so i thought maybe i pressed the display button cuz when u press it everything turns black , but i ddn't , and it worked except the screen was all black then i kept taking pictures and videos but it still was all black then late, like 5 hours later i turned mi camera on and took a picture and it was purplish with black ........
  • Canon Master
  • 4,738 Answers
Jvsnype and ygjeff21, have you checked to see if the pistures also come up as blank or distorted (a sure sign of a CCD failure)? If the pictures are OK, then it might be that you accidentally hit the DISP button, or the camera has a loose LCD ribbon cable connector. The reason I would suspect either is that ygjeff mentioned that the LCD would spring to life when he played with the buttons on the back of the camera.
If and only if the camera still takes good pics, and the DISP button has been checked, then would next recommend reseating the LCD ribbon cable into its connector (ALSO ONLY IF THE CAMERA IS NO LONGER UNDER WARRANTY). The following link may be of some help. Wouldn't recommend going any farther than the first three pictures. You just want to jiggle or reseat the ribbon cable where the LCD connects to the circuit board, nothing else:
http://photography-on-the.net/forum/showthread.php?t=251630
Posted on Feb 16, 2008
I deleted all pics from A540 but ended up with "no image" message on black screen. The shutter won't open either. It appears to be stuck in viewing mode.
hi,
first: be sure the battery is full charge.
second: by a compressor try to blow around the shatter and lens .
third : 3 or 4 times try to inflict a blow on the lens by your palm .
at the end see the result
good luck
gorbesia
Jun 15, 2011 | Canon PowerShot A540 Digital Camera
My Canon PowerShot SD880 IS has a black display screen. I cannot take pics now with the black screen, but the display DOES work for pics taken before the screen went black. Please help!
I don't have a solution, but I have the same problem. I found one posting elsewhere that said that this was a "common" problem. That person's camera was under warranty. Mine isn't, but it's less than 2 years old.
Oct 25, 2010 | Canon PowerShot SD880 IS Digital Camera
Black Screen
But does it take usefull pictures? I mean, after you take the picture, can you download it onto the computer?
  • If yes, you probably deactivated the back LCD by mistake. Look for a "display" button (or similar) and push it. It will cycle through all of the available display modes.
  • If not, it's probably a software error. Take the camera to a local electronist or Canon dealer for repairs.
Apr 09, 2010 | Canon PowerShot A540 Digital Camera
Hi, my powershot S60 auto setting will only take movie images no still pic's. I've reset to manuf. settings but still no change. Any ideas whats wrong & how do I fix it?
What do you mean by "no still pics"? What exactly is happening? If the camera is showing a black or distorted screen when set to photo, and photos that are taken with the black screen also show up black or distorted, then this would likely be a CCD imager failure, a common occurrence for your model camera.
If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 30, 2009 | Canon PowerShot S60 Digital Camera
The Display Monitor does'nt work after getting wet in an auto accident
if u can take pics and they are ok on pc then if u want to replace the lcd then i can help u find and replace one but spending 60 $ on this camera is not recommended u can ask me more on buying a new camera in 125 $ range or see this for lcd part
http://cgi.ebay.com/CANON-A540-LCD-SCREEN-REPLACEMENT-REPAIR-PART_W0QQitemZ370184524691QQcmdZViewItem
pls rate me well !
Regards
Aug 11, 2009 | Canon PowerShot A540 Digital Camera
Connecting the Canon Powershot A540 to a computer
First you should have a program installed in your computer to transfer your pictures, best is canon's.
Once the USB cable is connected you should turn your camera on, automatictly the program detects your camera and asks you to press the transfering button. Good Luck.
Sep 21, 2008 | Canon PowerShot A540 Digital Camera
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 27, 2008 | Canon PowerShot A540 Digital Camera
As web camera
Yes, I think so, using the included A/V cable.
Jan 04, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A450 Digital Camera Logo
289 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
