Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black and Decker Electric Lawn Mower MM850 wiring diagram
Hi, need to know the wiring diagram, four wires, one red, one white, two black one black with plastic coating other black no coating.
  • 3 more comments
  • Anonymous Mar 24, 2008
    how do you bypass switch on mower
  • pool prodigy May 13, 2008
    installing new switch.need wiring diagram for mm850.need to know wich color wire goes on wich terminals.
  • Anonymous Apr 17, 2009
    I have the same problem but I dont know where to locate another switch the one I have is fryed
    I have been thinking about bypassing the switch does anyone have any sugestions
  • fanyangto May 11, 2010
    Axio Your explanation of this problem is perfect. I picked up a black &decker M600 on the street. The same problem - the contact for the motorcircuit is badly burnt even though it's 8/10 new machine to me. Thecontact for the starting circuit, however, remains pretty clean.Swapping them and the machine runs again. But I won't expect this lastvery long before the switch gets burnt again. The problem is also reported by an amazon reviewer. http://www.amazon.com/review/R2PPC2YREXO... If you could tell us what new switch to buy (part number?) to replace this poorly designed switch, that would be super. I don't want to buy yet another switch that may not last very long.
  • Anonymous Mar 23, 2014
    do not know what with wire for coil
  • 4 Answers
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
    New Friend:
Where can I to buy brush for electric mower as mm850?
Posted on Jun 16, 2013
Show wiring for electric lawnmower , is it capactor run or start? Still runs with only two wirers only two blacks and a whhite
Posted on Oct 26, 2010
There is a solution for this problem at another website, the link is
http://www.ridgidforum.com/forum/showthread.php?t=8535
check it out and good luck
Posted on Mar 26, 2008
My rectifier swith went on my mower that's why none of the wiring combinations worked for me. Rectifier switch for electric lawn mowers Document Type and Number: United States Patent 4430604
Abstract: A switch is disclosed which includes both a switching assembly and a bridge rectifier, the switch assembly including contacts for connecting a DC motor such as the motor of an electric lawn mower, to AC supply lines or for short-circuiting the motor to rapidly stop rotation of the motor. Diodes of the bridge rectifier have terminals which are directly secured to portions of metal members which also carry contacts of the switch and/or serve as terminals for connection to the motor or the supply lines.
Posted on Sep 21, 2008
Radio/amp wiring diagram 2004 hyundai xg350 ?
2004 Hyundai XG350 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Dec 22, 2016 | Hyundai Cars & Trucks
Hi - I have a Heil outside airconditioner unit - I had pulled out two wires from it and was wondering what those wires do and how to reconnect them - it was a thin black wire that had two wires coming out...
They probably come from the thermostat inside and go to the low voltage connections on the contactor in the outside unit. Those will be the connections for the coil in the contactor. Let me know if you have any questions.
Jun 20, 2010 | Heating & Cooling
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
I recieved a ds lite with water damage and the four odd wires on my ds lite motherboard all come off does any one have a diagram of where the wires might go thanks please help
from the tom screen there should only be 2 wires 1 black and 1 white. The white wire is the mic that plugs straight onto the board, and the black wire which plugs onto the wirless insert which attaches onto the board. the other 2 wires could be loose speaker wires if there is another black and a red wire, other than that could you explain a bit further what the wires actually look like.
Jan 16, 2010 | Nintendo DS Lite Console
Wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Jan 01, 2010 | Clarion DRX6475
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
10,908 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
