i have the same problem, i downloaded the especify driver to my computer and i cant install....i dont know way! please reply me if u have a solution for this problem.... and email me.
Thank u!i have the same problem, i downloaded the especify driver to my computer and i cant install....i dont know way! please reply me if u have a solution for this problem.... and email me.
Thank u!
AnonymousAug 10, 2008
no soundno sound
You can't post conmments that contain an email address.
Here is where to find the drivers... http://www.emachines.com/support/drivers.html
You need to follow the prompts in the blue boxes, to ID your pc model, then under the boxes showing the model, you need to choose your operating system from the drop down pick list.
Then it will show you all the drivers available for your model.
For that first open cpu cabinet then refix RAM memory. Find cmos cell
on motherbord pull cmos cell for 15minutes then refix so all settings
goes to factory defaults. Remove pci cards from mother bord then check
display. Open processor fan and porcessor remove dust from all parts.] Let me know if you need more assistance. Thanks.
to upgrade a motherboard... you would need to replace it with another one, on a motherboard you can upgrade memory, cpu, video card, hard drive, parts that are connected to it, but you don't really upgrade the motherboard itself..
Here's the Support Link for your desktop. Look under User Guides, Hardware Reference. Also look on the motherboard for markings such as PW or PS and an indicator to where the wire goes.
This computer runs an Intel® PRO 10/100Mbps integrated Ethernet hence if you are running windows XP or Vista you should not need to install it. it will do so automatically. may I ask if youa re getting errors when you connect to a network over wired?
First check to see if a drive died. Unplug all the drive Floppy, hard and dvd or burns. I have come across many time that a drive will die and keep motherboard from booting. Being that you say you get a green light on the motherboard shows that the power suppy is providing some power. But for some reason the internal self test is faulting the power suppy. I have not come cross any bad power supplies killing a motherboard. But I have come across power supplies killing drives. The power switch is a normal open switch so the only time you be able test continuity on it is if you hold the switch in, or the closed position.
speaker icon is not appearing on status bar. No sound problem.
and email me.
Thank u!
no sound
