Question about ASUS P5S800-VM Motherboard
Asus P45GX-MX Hi there, A friend of mine connected the power connector at the side of the processor wrong and when I connected it right it didnt work is the board gone totally is there anything I can do to make it work again
    Master:
    Sergeant:
  • 440 Answers
Might have shocked the borad most likely bad or power is
Posted on Feb 06, 2008
When i switch on the system it starts the booting for 5 seconds and then it stops . which means the processor is running only for 5 seconds
i guess there is problem in your power button....interchange the reset connector and with power button connector from motherboard side.......if problem still exist try googling SMPS.....do reply back
Oct 30, 2009 | ASUS M2N-MX Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Can't boot
i should have thank u, if u add some more details in ur query, anyway check the following :
1. check if ur power cable is properly connected and free from damage or broken
2. did u see any blinking indicators on ur front panel
3. open the cabinet and look if the fans are spining
4. did u hear any beeps during (POST) startup
***** if ur answer to the above is YES, then
remove all the power connectors (outside and inside) , all the add on cards, RAM sticks, (and also the processor if u have a pair of smart hand), carefully clean and blow out dusts, and reinsert all of them to thier respective places, and try again.
If u find all these solutions useless, ur processor or RAM or mainboard might defective.
May 06, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
No power to newlt built pc help please !!!!!!!
some simple questions first is processor installed and locked in same with ram. does the MB have a squar plugin next to processor if so is the two yellow and two black connector pluged into it from power supply then is ram right front bus speed fpr the MB and is the processor the right FSB for the MB. this is very important your MB will not turn on if incorrect send me the MB numbers and i will try to get you straight thank you james
Mar 21, 2009 | ASUS K8V-MX Motherboard
How to solve the asus K8V-Mx mother board
SANDEEPDATAS
try resetting bios first if that doesnt work check for dust around the first ram chip and slot
remove the dust and retry if that doesnt work try another psu if you have one
let me know if we need to go further
rhodnhelm
go to the asus site
support
downloads
select from right hand side motherboards skt754 k8v-mx hit search
select o/s and there are your drivers
Oct 30, 2008 | ASUS K8V-MX Motherboard
Asus P4GE-MX
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Jan 15, 2008 | ASUS P4GE-MX Motherboard
Motherboard for asus
I was unable to find the specific model of your motherboard on the Asus site or from a Yahoo lookup. However you may wish to try the following
Check for actual model number per Asus
http://support.asus.com/repair/repair.aspx?root=110&SLanguage=en-us
Then use either auto-direct to download or general information to locate your motherboard on this link.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I hope this helps
Jan 01, 2008 | Computers & Internet
Motherboard
support.asus.com
scroll to the legacy products and get your drivers.
Jan 01, 2008 | Intel Motherboard
Monitor not Running(shows only orange light)
Unplug everything from the motherboard leaving only processor, fan and memory and try to boot up. It will take you to bios screen halt after looking for boot device. If it uses a video card, make sure video card is properly inserted. Then start plugging in hard drive and other devices if system comes up.
Dec 26, 2006 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
ASUS P5S800-VM Motherboard Logo
834 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
