Question about LG DU-42PX12XC 42 in. Plasma HDTV
LG DU-42PX12X Verticle lines of various colors, and widths throughout the screen.
I have an LG DU-42PX12X. When powered on, it displays verticle lines of various colors, and widths throughout the screen. Here is a picture of what i am talking about:
Please let me know what I should do/can do to fix it--or at least figure out more about the problem.
  • 1 more comment
  • sudilos Jul 25, 2008
    Same problem, only mine is on one side. Goes away after half an hour for an hour then comes back. If I tweak the case it'll go away or come back or change colors. I heard it was the right side PCB that controls the left side half of the screen that is the problem. Does that sound true or what?
  • ruroos1 Sep 07, 2008
    same problem only on outer edge of screen
  • rayshim May 06, 2009
    I have the same problem of mutiple color vertical lines on the left side. What is the difference between 6871QCH038C and the 6871QCH038A? I read somewhere it is the 6870QCH003A.
Check within you area for a reliable LG repair center. To fix the problem of the blue, red or green vertical line you just need to replace the control board PN 6871QCH038C. The part cost about $150.00 and a honest repair center should not beat you up to bad on the labor. Good luck and Good viewing.
Posted on Sep 10, 2008
This problem is caused by a fouled control board 6871QCH038A. I swapped it out and BAM! problem solved!
Posted on Jan 14, 2009
  • JasonKoller Feb 18, 2011
    I know this post is old,
    But I had the same problem.
    I was able to fix it.
    Heres a write up I did on the "How To".
    I added pictures and diagrams too.
  • 113 Answers
Sorry to tell you your set has a defective panel and the cost to replace the panel is more than what the tv is worth. If this set is out of warranty it is pretty much shot. Panel is listing at a cost of about 2200 dollars. Sorry I know this is not what you wanted to hear.
Posted on Feb 06, 2008
We have a Sony Grand Wega KDF-50A10We just started having an issue with verticle lines in the picture that extend from the top down about 1/3 of the screen. There are similar diagonal lines on the bottom...
It will be best for you to visit the site linked here. It has screen-shots to defective LCD screens, and details about the faults. You can compare them to that of your TVs' and can determine the cause of the fault. If you wish to get more details, check this.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 29, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
32" Sanyo picture is half verticle lines various colors, half ok picture
Bad Tcon board or the cable going from the board to the panel, try that first by cleaning both ends if that doesn't help you need a new board
Jan 27, 2018 | Sanyo DP32746 32 in. LCD Television
Jumping lines throughout the screen affecting quality of picture
You didn't say weather the lines are verticle or horizontal, but if the lines are verticle check the circuit for a weak capacitor or if the lines are check the horizontal circuit for a weak capacitor. During your check check for cold solder joints, idf you come across ant re-solder then. Good luck.
Jan 27, 2011 | Pioneer PRO-520HD 53" Rear Projection...
My TV Screen just turned off, but I hear the sound, have no menu.
Jan 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
LG Model# RT -42PX11,screen is not working.. shows verticle line color pattens and turns shades of black when a button is pressed
My LG RT-42PX11 after a few minutes the screen starts to flicker and colors go psychedelic and after some time no picture at all
Oct 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Verticle lines for picture
You need to describe these lines better. Are they moving or stationary? Are they very fine lines with sharp edges or are they more like bands with soft edges? How many lines do you see, and how wide are they (compared to the screen width)?
Fine lines that are stationary: defect in the electronics causing a vertical row of pixels to be dead or stuck. Can only be fixed by replacing major parts.
Broad lines with soft edges that move: could be electrical "hum" interference. Make sure you are using a grounded (3-pin) power plug, and that the outlet is properly wired. (Take the TV to a another location and see if the problem goes away).
Make sure you don't have fluorescent light fixtures nearby--they can interfere with the picture if the bulbs or ballast is defective. Could mean tecon board or display is bad which means replacing both in a sony if they are bad i recomend buying a new tv because it is not cost effective to replace these.
Jul 13, 2009 | Sony Televison & Video
Monitor displays verticle coloured lines when turned on
As i understood the explanation you have a problem with the Video card not the LG Monitor.
Jun 19, 2009 | LG Flatron W2242P-SF 22" Monitor
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical lines all over...have pic
I had the same problem on my DU-42px12xc. Red, green , and blue lines vertically on the right side of the screen. I found a loose solder connection under the inputs board on a resistor. After re-soldering, everything was crystal. I'm happy I grabbed this tv before my work threw it out. Be very careful when soldering SMT components. Use proper equipment. I had to troubleshoot while the tv was on, so I was extremely careful not to short anything out.
I pulled the inputs board out to gain access to the "Y-axis" pins.
41d5250.jpg resistor located under the inputs
fd8bf0e.jpg9d002b6.jpg I started pushing on the resistors 'till the color lines started working correctly, and re-soldered the four resistors.
Jan 23, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
LG DU-42PX12XC 42 in. Plasma HDTV Logo
1,954 people viewed this question
Computer Repairing
Computer Repairing
