Question about Philips Magnavox 42MF521D/37 Television
Magnavox model number 42mf230A/37
I am swaping out tvs for my main one and the magnavox was working fine until we put it in the new location. when i plug it in the power light is red meaning it is off and then when i turn it on the light turns blue but i cannot do anything on the tv not even turn it back off without unplugging it. I also dont have a remote for it but the mode and menu on the panel used to work to get into the tv menus. Any suggestions?
  • 1 more comment
  • Lucas Myer Nov 13, 2008
    Same Problem. I can plug in tv and try to power it up. Sound will come on for a few sec and you will hear 2 clicks. and it shuts off. The power light on front is still on and blue. At this point you have to unplug the tv to try to power it on agine. If you get it on it works great. Just dont turn it off. I took the back cover off and when you power it on 2 green leds come on and when it clicks off a red led light comes on. Any thoughts. Thanks
    42mf230A/37
  • william_r_lu Feb 08, 2009
    I have a 42MF230A/37. It has worked great for 2 or 3 years. Then I decided to move it to another spot in the living room. It seems the new outlet works fine. But the TV works for 10 minutes, then shuts off. I can turn it right back on, but it will shut off in 10 minutes. Ugh.
  • carzose Mar 02, 2009
    When we turn the unit on, the screen stays blank but the sound works. Before, we try two or three times and the picture came. Now only have a sound.
I have a xtra remote
Posted on Mar 09, 2008
Magnavox 51MP6200D/37 has no sound or picture. Flashing code 68 (6 long, 8 rapid) on on/off button. What does code 68 indicate for this model?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips & Magnavox TVs are entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 25, 2015 | Magnavox Televison & Video
I need help in identifying a problem with my Magnavox Flat screen TV. Model ID: 47MF437B/37. Serial # BZ5A0744161658. When turning it on. Get no picture or sound just the LED red light flashes with a...
Circuits to Magnavox and Philips are alike; and the blinking codes too might be.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jan 31, 2015 | Magnavox Televison & Video
Direct TV code for 2006 Magnavox model 42MF230A/37
Contact DirecTV's customer service. They have a pretty simple setup system for adding remotes.
Jan 18, 2015 | Magnavox Televison & Video
Magnavox/samsung 42MF230A/37 plasma t.v. turns on, no picture.
the only way to check it is to change out boards. the "sugar cubes" are ceramic resistors and should get hot. if you have the correct voltages on the p/s then you will need to replace both the y and z boards. better off buying a new tv. consider letting a professional tech. check it for you, this is not something to be tried unless you know what you are doing. if you really want to do it yourself get the service manual and a voltmeter.
Mar 24, 2010 | Televison & Video
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
I have a magnavox 42mf230a/37 with black screen
more that likely your set got a serge and bleew a couple of capacitors in the power supply esay to find they will have dome on the tops from venting
Sep 17, 2009 | Televison & Video
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox plasma tv model 42mf230A/37
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
Mar 29, 2008 | Televison & Video
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
Philips Magnavox 42MF521D/37 Television Logo
729 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
