Question about Maytag Atlantis MDE7400AY Electric Dryer
SQUEAKY DRYER My Maytag Atlantis started making a high pitch squealing noise it does stop briefly but then starts again. What can I do to make it stop?
  • 3 more comments
  • tomdou Feb 09, 2008
    how do i get to the rear bearing
  • Anonymous May 02, 2008
    i have the same problem with my Maytag Atlantis (model MDG7600AWW) dryer.
  • Anonymous May 30, 2008
    I have the mdg7400 making the same noise
  • Anonymous Mar 25, 2009
    dryer sqeaks
  • Anonymous Mar 25, 2014
    When the dryer is running it makes a squealing noise
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Posted on Mar 31, 2009
  • 883 Answers
The bearing needs lubrication. access the rear of drum and apply a few drops of motor oil on the bushing (bearing)
Posted on Feb 06, 2008
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My Maytag Atlantis Gas Dryer makes a loud noise when it is running. It works fine except for the noise. I have had the dryer about 5 yrs and this noise just started several days ago.
is it a high pitch noise. Like a noise that sounds similar to a old freddy cruger movie when the little girl on the tricycle passing by. If it sounds like that, then maybe you idler pully needs to be oiled..the idler pully is what keeps tension on the belt and lets the belt rotate smoothly. just like a pully. That maybe needs to be oiled..try doing that and see that works.
Jul 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | Dryers
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis dryer
Why is Maytag Atlantis is not drying like it use to?
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,059 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
