Question about Dell Inspiron 6400 Notebook
Volume control icon dissappeared
Hi. After uninstalling a few programs, a few settings in my inspiron 6400 got screwed up. Im now trying to fix them one by one. One of these is the Volume control that appears on the lower right corner when you adjust the volume. It wont come up anymore. Can anyone tell me how to get it back up, or how to revert to the original computer settings (which would be even better) Thanks in advance!
  • rico355 Feb 06, 2008
    No guys the problem remains, I've noticed its not only with the volume, but other icons that should appear when i use the hotkeys (hotkeys are working), for example, when I lower the brightness a sun icon usually came up to show me how bright it is, its not anymore.
    President:
  • 2,351 Answers
Open Control Panel, Open Sound & Audio Devices. Click the Audio tab. Check what device is listed, Sound playback device? Click the Voice tab, it should list the same device. You can reinstall the driver software from the Dell download site listed below. Fact all your drivers here are listed.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
Every file you install uncompress it's self & creats it's own folder inside the main folder located on your drive named Dell. Keep this in mind because windows may loose the path to a driver. You will have to show windows where the driver files are. Now your armed with that knowlage (just in case).
Luck!
please vote...
Posted on Feb 06, 2008
  • Mike Peluso
    Mike Peluso Feb 07, 2008
    So when you open control panel & open Sound & Audio devices the check mark is checked to place volume icon in the taskbar? While your there see if a device is listed in Audio & voice? Lastly, I'd like you to open System listed in control panel. Click on the Hardware tab & than click on Device manager. Notice any yellow ! ? Post your answers.
  • Mike Peluso
    Mike Peluso Feb 08, 2008
    There is always system restore!
  • 432 Answers
I uninstalled my volume, now i dont hear a thing and i have done the control panel thing, but the sound section is blank. what do i download to get my volume back on my computer. my laptop is windows xp
Hi good day "Topsychicc"
you can easily fix this problem by yourself, find your Dell inspiron 6400 laptop driver from their website,find your "service tag" from bottom of your laptop then search driver  from their website mentioned below http://support.dell.com/support/downloads/
then download and install your audio driver...
Aug 27, 2011 | Dell Inspiron 6400 Notebook
No sound volume control icon disappeared
you can go to control panel, look for sound , then open sound properties and under volume tab put a check mark on Place volume incon in the taskbar
Jul 16, 2010 | Dell Inspiron 6400 Notebook
Web cam works but microphone does not work
Hi There, check your microphone settings. Click volume control in the taskbar, and check microphone level. If that doesn't work, try looking in control panel with the microphone settings.
Jan 18, 2010 | Dell Inspiron 6400 Notebook
The volume control icon that appears on the tool bar at the bottom has dissappeared
Open control panel/click sound icon/first tab speakers/there is a switch to click off/on for desktop screen bar (Or something like that?)
Nov 14, 2009 | Dell Inspiron 1501 Notebook
The volume won't work anymore, it says the audio device supported by this application is not detected, the application will exit. was working grand yesterday
it,s saying the audio Device used by this Application ( Program )
Is not detected.
The problem most likely is with the program i.e media-Player, Cyberlink Power DVD Et,c.
uninstall and re-install your Audio/Music Application.
Also check the devices/Drivers are not corrupt or not installed.
Mike @ Compurepair,
Nov 05, 2009 | Dell Inspiron 6400 Notebook
I am not getting sound
check volume on copmputer or maybe iys on mute
Oct 27, 2009 | Dell Inspiron 6400 Notebook
Hi i have a problem with my java working for runescape...it lets me play the game for like 5mins then the game dissappears and the screen is black and my java icon on the bottom right corner (next to the...
awesome, someone else plays runescape also!. just uninstall your current version of java, then go to the java website and reinstall. should fix this issue. im level 93 by the way!
Mar 13, 2009 | Sun Java Desktop System
External Mike not working
Try this:
Double click on the volume icon on the system bar (lower righ corner, asuming you are using windows), this will display the volume controls. Now, click on Otions -> Properties and select "Record", MAYBE you will need to change the Mixing Device in order to do this, click on accept or ok and the volume panel now contains the recording volume controls, check the silence mark ys not checked for the mic, adjust your volume settings if needed. Good Luck!.
To get the original volume config, just do the same selecting the play option.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
No sound on my computer
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devices such as playing a CD or the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a yellow "Warning" icon superimposed on the 'speaker' icon there is your problem! Missing or corrupt drivers.
If no "Warning" icons then try...
Click on the blue icon on the second row, (it looks like a large key in front of a monitor) that says "Scan for hardware changes" when you hover your mouse on it.
One at a time...
Double click on each of the devices that have 'Audio' in the listings.
Click the "Properties" tab; look for any "Warning" icons.
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty device and hit the "remove" button, follow the instructions given by the program.
(This uninstalls the DRIVERS)
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Nov 12, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 Notebook Logo
88 people viewed this question
Alun Cox
