Question about Lexmark JetPrinter X1185 All-In-One InkJet
LexmarkZ25jetink printer can not get to print please help
I can get hooked up to the internet and i have checked everything all the wires are good printer in wall socket... it shows default printer but will not print
  • 432 Answers
In IE 6 or 7, go to Tools> Internet Options> Advanced> Scroll down to printers and check 'Print Background and Colors'.
Then, click on 'Start' button (bottom left of screen), 'Settings' > 'Printers and faxes'. Right click on printer icon. Then click on 'sharing...'. Follow the default prompts for network printing
Posted on Feb 06, 2008
I have lost instruction leaflet and do not know how to operate printer
1. Using a printer even basic printer is extremely easy to do. There are many different models of printers out there. You have your very basic to your all-in-one printer. The printer with everything on it works pretty much just like the regular printer you just have a lot more buttons to push.
2. Make sure that your printer is hooked up properly before using it. If this is a brand new printer then it will go through a check and print out a test page for you. A lot of different times you can just turn it on, you will hear the ink moving around. Something might come up on the computer telling you that the printer is on and working properly.
3. Open the page you want to print. If you are on the Internet and want to print something from there. All you have to do is go up to file, then down to page set up. This will give you more printing options to choose from. When you are done setting up the page you can verify you have the right printer hooked up by clicking on "Printer" at the bottom. Once everything looks good click on "OK" and now your page should print out.
4. Open up a ".doc" file if that is where your page is that you need to print. When you are ready to print go up to "File" and "Print Setup". Again you can choose how you want your page to look, and check and make sure the right printer is installed. If your page is set up the way you like it you can just click on the printer icon on the tool bar or go to "File" then "Print."
5. Using a printer a lot over time will start to wear down your ink supply. Some models of printers let you know when your ink supply is getting low. If you have an older printer you will just have to go by what the printed page looks like. If it is very worn and faded then it is time to install a new ink cartridge.
Printer Help
Nov 11, 2010 | Office Equipment & Supplies
A message keeps saying print cartridge access door
check that sensor function while open / close upper cover, some time hook type sensor connector broken and need replacement. check also roller for possible stock paper.
Apr 04, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Dell all in one 924 printer will not print from internet
If its only a problem while printing from the internet webpages, I think it would be an issue with your browser.Try using a different browser like Mozilla Firefox or Google Chrome. You can also try resetting your IE settings, delete temporary files and cookies, try reinstalling the printer again. If nothing works, look for program permissions under your Firewall program and ensure that anything related to Printer Communication System is whitelisted.
Good Luck!
Abhishek
Apr 03, 2009 | Dell 924 All-in-One InkJet Printer
Setting up printer
THIS IN ON THE INTERNET PROVIDE I THINK IT IS SAY YOU ARE WORKING OFF LINE, AAL YOU HAVE TO DO IS GO TO FILE LOOK FOR WORKING OFF LINE AND REMOVE THE CHECK MARK AND EVERYTHING SHOULD WORK.
ROD
Feb 05, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Will not copy info. off the internet
Are you able to print from other applications like a microsoft word page, or a print test page. If thats the case than check your Internet options. If you are using an Internet EXplorer web browser than try to set all  internet settings on the option menu to default. This should resolve the issue. Else try to  use a HP 990C pritner. Add the 990C printer and try to print an internet page, it should work.
Jan 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have a HP Photosmart C7280 I ran network configuration page and it says everything is ok. But I can't print anything off the internet How do I no if everything is connectd by the way I have a wireless...
Verify that the printer is getting a good IP address.
Then go to the Control Panel >printer and Faxes>click on your printer.
Then ports . There check to make sure that the printer is showing up next to the box that has the same IP address as your printer. If it does not , put a check mark in the box with the IP address. Then try to print a test page.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 10, 2008 | Office Equipment & Supplies
No print of the Internet Address Bar
In Internet Explorer 7 do the following to remove the internet addresses from the top and bottom of each printed page.
Start IE&
Click "File"
Click "Page Setup..."
Look for the "Headers and Footers" section of the Page Setup control panel.
Remove everything in the "Header" and "Footer" fields.
Click "OK"
Let me know how it goes.
Jan 08, 2008 | Computers & Internet
Printing Problem
Your printer disc and printer are being technically stubborn!!! It may have picked up some little glitches when you moved. This can and will happen. First, make a back up copy of the printer disk. Uninstall the printer once more, but this time, reinstall it with the back up disc, not the original. Post back if no good.
Aug 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
