Question about Vizio P2 42 in. HD-Ready Plasma Television
The picture has shrunk - maybe 720P vs 480P?
We have had this Vizio P42HD for 2 or 3 years. Suddenly, the picture has shrunk. There are two settings which control picture size: Zoom and Wide. We've always had Zoom=normal and Wide=aspect. We can now get an HD signal to fill the screen only by setting Zoom=Zoom2 and Wide=Wide. This fills the screen, but it seems like there is some distortion and, I think, picture degradation.
We've tried every setting we can find on the TV and had the cable guy out at well. I'm fairly certain it's not the signal because the picture has shrunk from all sources (cable box, dvd player, XBox).
The only guess we've come up with is that in the Setup menu it shows the resolution as DVI: 480P. This is labeled as "Info" and doesn't seem to be changeable. The specs say that the TV is capable of 720P. Can anyone suggest how we could change the resolution to 720P, or why we can't? Can anyone suggest a different cause for our shrunken picture?
  • Alex42Plasma Mar 21, 2008
    I too have more or less of the same problem, grainy resolution. I've tried inputs (DVD up-conversion Component and HDMI connections, ATT-"U-verse" set top box,) to get the 1080i mode to work. For instance, when the DVD's HDMI cable is connected, it displays a "snowy white screen with small Red/Blue/Black pixels for a second then alternates back and forth to a blank display. Note the "Setup" screen, it shows 480p with the use of the Att-U-verse set-top-box, and the DVD Up-conversion is reads 1080i but with no picture-its just  alternates back and forth to a snow and blank screen. Is there any way of resetting or process of the repair or possible Circuit Board swap.
    Thanks in Advanced
I have a 63inch lg plasma tv its about 3 to 4 yrs old, i have satellite and suddenly the picture has shrunk, when it is put on zoom the picture will fill the whole screen . my question is should i have the satellite co , come out and check my box , a tv repairman, or is it comething i can do to fix the problem.
jh
Posted on Nov 13, 2013
    Scholar:
  • 84 Answers
Make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Posted on Feb 06, 2008
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Visio 42in. Plasma TV
The TV is a Plasma, it does not have a "BackLight" as it were, that is for LCD's only.
Vizio are fobbing you off. It will need either a Y-Sustain & Buffers or a Z-Sustain.
Sep 06, 2009 | Vizio P42HD Television
No picture on vizio lcd
It's likely not a backlight, but a mainboard. If you are feeling frisky, take the back off and get the model number off the mainboard and check eBay.
Jul 26, 2009 | Vizio P42HD Television
Is the protron pltv32cm a high definition tv . I bought it in 2005.
Kind of. It is capable of 720p. So channels like FOX, the ESPN channels, SPEED, and other 720p broadcasts will look fantastic on that display. However, the 1080i broadcasts will be shrunk to fit your screen. They'll still look pretty good, though. Most people consider HDTV to be anything above & beyond 480p (so, 720p, 1080i, 1080p).
Apr 07, 2009 | Protron PLTV-32 Television
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Picture not filling up the screen
The Vizio HDTV sets are all software driven. With the remote control select the menu option.
Then under the picture tab. look for the picture format full screen, wide screen. select the wide screen option. This setting should fill the screen.
Hope this helps
Bruce
Mar 27, 2009 | Vizio P42HD Television
Vizio P42HDe Plasma TV - Audio, but no picture
check the backlight inverter and the Y-sus board the one to your left. if those are fine check the bottom right buffer board
Mar 03, 2009 | Vizio P42HD Television
New vizio 42" is posterizing
I think it cause by vs voltage is high. You can try to decrease the Vs voltage a little bit. You can adjust the voltage while the TV is on. The Vs voltage adjustment is locate in the power supply.
Feb 01, 2009 | Vizio P42HD Television
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
784 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
