Question about Minolta DiALTA Di520 Laser Printer
Minolta Di520 false misfeed
Copier is showing a misfeed at the misfeed guide removal unit (M5). I pulled out the tray and checked for paper, but have found none. I also checked the visible sensors for possible paper fragments again, found none. Not sure what to check next. Any suggestion appreciated.
  • 300 Answers
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Posted on May 18, 2008
How i assemble di520 bottom tray lock
Step 1:
Remove the rear cover and in area of wastw tonwr box remove the tray blocking unit.2_3_2013_6_10_50_pm.jpg
Step 2:
Jan 22, 2013 | Konica Minolta Minolta Di520 Dialta Color...
Misfeed
Pull out the first tray and the second tray.The sensors located on the paper feed roller assy.
Jan 16, 2013 | Konica Minolta Minolta Di351 DiAlta...
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Misfeed when attempting to make a copy - Ricoh FT5535
If you are a technical person you may want to remove the tray from the machine (pull all the way out, tilt upwards, and pull.) to clean the rollers. Once the trays are removed you will see a set of three rollers for each tray. They can be removed and cleaned or cleaned directly on the machine. They may have build up dust on them preventing feed. Reinstall the trays the same way they came out but in reverse steps.
Then:
1. Pull offending tray all the way out and remove paper.
2. Unlock the side guides and make sure they move freely
3. Set about 100 sheets of NEW paper for now and adjust the side guides and the end fence. The end fence must be against the paper (touching) and the side guides must NOT be too tight agains the paper as this will prevent the tray from lifting.
4. Make sure the paper size dial is set to the paper SIZE and ORIENTATION.
5. Close tray and test.
Let us know what happens. In the worst case it could be a Magnetic clutch malfunction
Aug 28, 2009 | Ricoh Office Equipment & Supplies
C 0924
Paper misfeed in rear side to paper tray,blocking the paper actuator or sensors.
Jul 21, 2009 | Minolta DiALTA Di520 Laser Printer
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Misfeed
Your running double sided copies? Have you open the duplex section? What type pape using
Mar 28, 2009 | Konica Minolta Office Equipment & Supplies
Minolta cf2002 misfeed error
Have you checked that the paper matches the operator panel and the paper draw, landscape vise portrit
Mar 17, 2009 | Konica Minolta DiALTA CF910 Copier
284 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
