Question about IBM PC 300GL PC Desktop
Power on but, No beep?
Hi! I hope that you will quite well. There are some Critical problem in my System, first problem in my computer that is No beep... many times RAM plug and unplug but invain... no display, no beep. I am very worry about my computer so, so what is the reson?
    Genius:
  • 3,587 Answers
You may want to boot from the install disk, in CD area, to see if you have a blown hard drive.
Posted on Feb 06, 2008
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    I'm deeply grateful to be of some minor assistance.
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
MY CD WILL NOT EJECT FROM MY PLAYSTATION 3 AND THE LIGHT BLINKS GREEN THEN YELLOW FOR A SECOND
you are a victim of the dreaded yellow light of death my friend your options are limited the console is fixable but not easily yellow light is a critical hardware failure the disc hopefully not important is possible to retrieve by putting the blu-ray rom from your console into another console to eject it
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
due to your yellow light problem i think ths recovery menu is a shot in the dark but 1 try cant hurt ok hope this helps
Nov 17, 2010 | Audio Players & Recorders
When i turn my computer on it has a long beep sound and then another long beep and wont quit... please help
Check your MEMORY MODULES . Try removing them, cleaning them with rubbing alcohol and the reinstalling them. Re-boot. That should work, ok?
Oct 18, 2010 | Acer Computers & Internet
SWITCHES ON, FANS ARE RUNNING,NO DISPLAY SHOWING ,NO BEEPS OR ERROR. HAVE REPLACED THE MAINBOARD,DOING EXACTLY THE SAME THING
Hi Patrick,
I have seen this a few times over the years. It is a very common assumption that if the fans are running, then the power supply must be good. This is not a good assumption to make. It is actually quite common to have a power supply work enough to turn on fans but not be able to actually power up the system. Check this first, if this is not the problem, then you most likely have a dead CPU or dead Memory.
Hope this helps,
Brian
Jul 06, 2010 | IBM xSeries 226 Server
5 beeps are coming and after some time five beeps are repeating.system not booting
Hi ,
When you hear 5 beeps while booting or turning the computer off it is related to the operation of critical motherboard components - such as the CPU.Please try these steps to try fixing this problem .
Open up the computer tower and then once the side panel is out a test on the motherboard needs to be done and to do that look for the memory cards(Ram ) which would be green in colour,4 inches long and would be inserted in a slot that has clips in either ends that holds the card in the slot firmly.There can be one or more than one so remove the memory cards and then turn the computer on by just connecting the power cable,you should hear long beeping noise if you dont hear any then the motherboard needs to be replaced or needs to be serviced.
allthe best
May 20, 2010 | HP Workstation xw4200 PC Desktop
I am missing critical files, the computer freezes all the time, i have to crash the computer to end programs quit often
Missing critical files? Re-install your OS. You should have a boot disc. Put it in, and boot from that drive.
Oct 16, 2009 | Compaq Presario 5000 PC Desktop
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
Standard Original IBM POST Error Codes
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
My computer refuse to beep and display while booting,but other light are on
Hi when you say that your computer isn't beeping or displaying what exactly do you mean? Is there power getting to the system? Is the other light on the monitor? Are the drives firing up?
It may be that the power lead has come unplugged or, on some computers, the switch above the power supply at the back has been switched off.
Sorry to be vague but need more info.
Hope this helps
Apr 16, 2009 | Computers & Internet
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Power up problem
can you check if the memory modules are loose / dirty ?
Nov 07, 2008 | Computers & Internet
IBM PC 300GL PC Desktop Logo
90 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
