My air conditioner is making a high pitched squeal after about 15 minutes operation. I have just had a repairman regas it as he said it was leaking. The noise seemed to have gone away but when left on for 10-15 minutes it comes back.The high pitched noise is ear splitting!
    New Friend:
  • 23 Answers
If the squealing is comming from the outside unit then you might need a new condensor fan motor
Posted on Jan 08, 2010
SOURCE:
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
Engine Squeal, unsure where from, not belt, Sounds like vacuum leak, but can not find the source.
Squeal is always from the serpentine belt. Buy a can of Belt Conditioner, and spray it on the belt with the engine running. Sometimes you have to spray two days apart.
You can make a stethoscope by using a length of plastic tube and putting one end to your ear and the other end in the direction of the noise.
Dec 08, 2017 | 2002 Pontiac Montana
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Our water softener makes a high pitched squealing noise every 10 min. or so, and then quits for several hours only to start again during the night when we're trying to sleep. Our water softener repairman...
A softener will generally make a high pitch squeal when it is backwashing. This is generally the first cycle in most softeners. It may also do this during the final fast rinse cycle. The second brining cycle takes about an hour. That is why you may have a delay in the squeal. Also I have seen at times when a power surge can force the drive motor into a short backwash. Usually just a few minutes. It may help to put a surge surpressor at the water softener plug.
RJ
Aug 22, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
My bottom freezer has stopped producing cold air, fan still works, any thoughts ideas, Daniel
if the compressor keeps switching on and off in short bursts, its your gas thats finished. it may need a regas. gas being finished may be from either standing a long time, it being an old freezer, or a gas leak. you'll need a repairman to regas it and also for checking for leaks.
Oct 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
Indicator lights with high pitched squealing sounds.
check the alternator drive belt,it may be loose and squealing.
the alternator itself could be also making a noise.
start the car with the hood open and listen to it.
look if the belt is cracked,loose or wet from oil or water etc.
things like thermostat housings leaking coolant can cause something like that.
Sep 14, 2009 | 1999 Honda Accord
CARRIER MODEL 38YCA030370 MAKES HIGH PITCH ELECTRICAL HUMMING NOI
Yes it could be the pop off pressure relief on the compressor.
I assume it is the outdoor fan your referring to not running.
If this is a heat pump and it is in defrost (only in the heating mode should your outdoor fan be off and then for only a max of 12 to 15 minutes).
If it is just AC ir is Heat pump in cool mode, the out door fan should run while the compressor and indoor fan are on. Until the thermostat is satisfied on room temp.
This high pitched squealing is indicative of a bad fan motor or capacitor for the out door fan motor. Kill power and test blades to see if turns free. Check the run capacitor inside control panel. It is usually silver or aluminum colored (some are painted gray). The top should be flat with rolled edges and the sides should either be round or oval shaped with no swelling or oil leaking from inside it. If this all looks normal take it to where your going to get a motor any way and ask them to check it or sell you a replacement at the same time. These can go out usually from high voltage (lighting...) or from over heating (bad fan motor, dirty out door coil...).
Hope this helps you if not post back I'll respond as soon as I can. And please rate me as high as you can. Thank you for using Fix ya and good luck.
Mar 28, 2009 | Carrier 38CKC042 Air Conditioner
Our Pentair Challenger 1.5 hp self priming pump is squealing.
Where is the water leaking from and does the noise start only when the pump starts or the entire time its running..
Feb 09, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Heating & Cooling Logo
1,062 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
