Dell TrueMobile 2300 Router My cable modem works fine when connected to my computer. When I try to connect to my router...there is no connection.
I connected Ethernet cable from Modem to Router
Then connected Ethernet cable from Lan 1 to Computer...
The internet connections works just fine until I try to use it with the router.
I have cable internet through Charter Communications
What am I doing wrong??
SOURCE: Dell TrueMobile 2300 Wireless Router
If you are able can you reset the router in any way normally little reset button on back, or get into the routers set up page and try a restart.
SOURCE: Connecting my westell 6100 modem to my router
linkseys Wireless G broadband router need to hook up to Verizon router/modem
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
SOURCE: Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
