Question about Samsung RM255LASH Side by Side Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has never been full and we have had this refrigerator a week today. Help!! We need ICE!!!!
  • 29 Answers
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Posted on Mar 01, 2008
  • Stuart Bertles
    Stuart Bertles Jul 07, 2014
    Thank you for this tip! It helped...I had to set my freeze temp to -2
  • Christa Dening
    Christa Dening Jul 07, 2014
    You're welcome!
    New Friend:
I found the tip sheet enclosed in my manual and read where it said to set the freezer temp. to -2. My ice just wasn't freezing fast enough to drop more than like 3 times a day...not enough. My freezer was set at +8 initially. It's better now.
Posted on Jul 07, 2014
  • 4 Answers
Check my other entry on FixYa for my solution to the ice maker woes.. My ice maker quit making ice all together. I had to remove the ice maker and clean it out. Which turns out to be a pretty simple process.
http://www.fixya.com/support/t1141317-two_issues
Posted on Oct 31, 2008
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
My model is 596-50699001 and the problem is does't do ice, and change a filter what can I do to fix it ? Thankyou for helpingg me
There three problem that will not make your ice maker to make ice.
If the water’s route is blocked or the solenoid doesn’t work
If the bail wire is lifted—the ice maker won’t make ice.
Your home’s water pressure must be strong enough to serve an ice maker.
For your ice maker to maker ice,
be sure the bail wire above the ice tray is in the down position.
If the ice maker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
Also,check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
The water line attaches to a solenoid at the back of the refrigerator and then travels to the ice maker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first.
Check the tap valve; a bad tap valve may cause the problem where the ice maker supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Thanks for contacting Fixya.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator installed new 18 months ago. No ice
he should of replaced entire ice maker assy. sounds to me your module is bad.
Jun 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Samsung RM255LASH Side by Side Refrigerator Logo
1,945 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
