Question about NetGear DG834G 54 Mbps 802.11g Wireless ADSL Firewall Router w/4-port 10/100Mbps Switch (NTWRNGDG834G)
NetGear DG834G Router
I am not able to use the NetGear DG834G Router with MTNL broad band service wheras the other modems are able to connect
  • Anonymous Apr 13, 2008
    I am not able to confige the router to aol I follow the instructions on the CD supplied get 3 green lights then it tells me I have entered the wrong username and password
    I am unable to configure my router DG834G 802.11g to aol broadband despite following the CD provided to the letter i reach 3 green lights and then get told i have used the wrong password and user name I then created a new username and password as recomended by a netgear site and the same thing happens
    Fiesta man
  • 258 Answers
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Posted on Jan 15, 2009
I am using BSNL India broad band connection. I am not able to install my Netgear modem with router on my computer. on connecting the modem to the CPU, no further window is opened where i can enter user...
  1. follow the links hope this helps you
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Sep 13, 2010 | NetGear DG834G Router
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
My wireless router DG834G is not communicating with my laptop.
in the back side of netgear router you can find router rest switch.its hidden actually.but still you can find if you search for it.hold the switch for 30secs then reconfigure it and see.it should work properly.else ask netgear people for a replacement.
Sep 30, 2009 | NetGear DG834G Router
Netgear wireless modem router dg834g i have no disc with router also im on cable moden how do i change it over
ok... you ned assistance... the modem connects to the router... if you look at the back of the router it should say internet. thats where you connect your modem to. then everything goes through your router...email me and I will try and assist
Jun 21, 2009 | NetGear DG834G Router
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
Sep 15, 2008 | NetGear DG834G Router
Problem connecting to internet from PC to laptop
mY lAB TOP WAS CONNECTED THROUGHdlINK WIRELESS ROUTER VIA bROAD BAND mtnl mODEM. iT WAS WORKING BUT nOW IT HAS STOPPED CONNECTION THROUGH YOUR dLINK wIRELESS.
pLEASE SUJJEST
Aug 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
MTNL ADSL connection through G834 G Netgear Router
Goto Settings> Control Panel> Network Connection> Network Setup Wizard.
Create a New Network Connection using this method and retry after the system restarts.
Goto www.sahajayogamumbai.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
For anywhere else, goto www.sahajayoga.org.in or www.sahajayoga.org.
Feb 29, 2008 | NetGear DG834G Router
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Computers & Internet Logo
250 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
