Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Hooking up my cable
I just got this tv, sd-533hd5 and I must be doing something very wrong. I can not get my cable to work with it. I only get about 5 channels. Is there some kind of special programming to get the cable to fully work? I have the cable line running into the back of the tv where it is labeled "cable." Please help where you can, thanks.
  • 113 Answers
You will need to go into the menu and do a channel scan. Until the tv scans through all of the channels and finds them you will not get them. This is also where you would switch between air and cable. If you go through the menu untill you see this you will fix your tv.
Posted on Feb 06, 2008
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Have a 533HD5 and when on there is a blue shadow around objects tried to converge but could not adjust it much. Any suggestions?
Your tv is due for some convergence amplifier circuit repair, this requires replacing some components soldered in the circuit so it would not be something you might to take on if you do not have the necessary tools and equippment. depending on the type of power amps the tv uses it could be a repair that would run around 390dolls. always a good idea to call your local tv shops and check for prices. hope this helps. thanks!
Aug 27, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer model sd-533hd5 shuts off after 5 mins and goes to stand buy
Replace Both of your STKs ,if it has the STK392-110s do not go back with these they do not hold up use STK392-180s for parts call Electronix Parts 1-800-223-3205.
Dec 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Greenish color when using component to RGB connection
either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
for the settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Aug 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Can't sem to get the PIP to work
In order to use the PIP feature, you Must have 2 different sources to view. Your current connections prohibit this. See if you can get say, a DVD or VCR connection going into the set also and you've got a fix!...accordianman
Feb 18, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
81 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
