Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Viewmeter on Viewsonic crt monitor
I have 17" viewsonic CRT monitor.When I start to power on, the VIEWMETER on screen is missing.If you boot your CPU, nothing start at all.
But if YOU REST your monitor the whole night, the viewmeter will appear on screen and ready for use.
Its seems there's a problem on component of power supply ckt. Either horizontal, controller or switching.What shpd i Check.
It seems that utilizing the monitor for more than an hours and re-start again, the viewmeter will dis-appear.
  • jay hernandez Feb 06, 2008
    The problem is the monitor itself. I test it w/ other monitor and its ok.The viewmeter screen(self monitor test) is missing or no power to the crt itself.However the power led is at green(ON state).There is no raster on the monitor.
  • 983 Answers
Just check the power cable from the monitor is connected correctly and plug from cpu to monitor is connected properly be sure is there an loose contact... if it doesnt works means then give reset button in monitor... check the power and frequency control properties in bios .... may be properties is user define or is in maximum saving mode just change it to mininmum saving mode ...it will work...
Posted on Feb 06, 2008
Display in black with one line in 1/4 of the top
Hi.
Please try to connect other monitor to your CPU.because I know the problem is in your video card graphic.also change your screen resolution to 1024 by 768.
if same problem again. need to check-up your viewsonic p75f+ crt monitor. some parts of your vertical video section capacitor leakages.
Jun 13, 2011 | ViewSonic P75f+ (Beige) 17" CRT Monitor
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
I need info on my Professional Series P95f+ 19
CRT Type 19" (18.0" viewable), 90º deflection, PerfectFlat CRT Dot Pitch .25mm aperture grille at center, .27mm aperture grille at corners Phosphor RGB B22 medium-short persistence Glass Surface Tint: TM~43.5%, anti-reflection, anti-static with AR film INPUT SIGNAL Video RGB analog (75 ohms, 0.7 Vp-p) Sync H/V separated (TTL), composite Frequency fh: 30~110kHz; fv: 50~160Hz COMPATIBILITY PC VGA up to 2048x1536 Mac®* Power Mac™ G3/G4 up to 1920x1440 CONNECTOR Signal 15-pin mini D-sub Power 3-pin plug (IEC320) POWER Voltage AC 90-240VAC, 50-60Hz (+/-2)Hz Consumption 97W (typ) CONTROLS Basic Power, 1, down, up, 2, UltraBrite™ hot key On View® Contrast, brightness, H. size, H. position, V. size, V. position, pincushion, pin balance, trapezoid, parallelogram, rotation, degauss, moir reduction, H. convergence, V. convergence, ViewMeter® language, ViewMatch® color, data recall and zoom VIDEO INPUT Bandwidth 285MHz MISCONVERGENCE 0.25mm (max) at center
0.35mm (max) at corners DISPLAY AREA Factory Setting 353mm x 265mm (V) (typ) Maximum Scan 367mm x 275mm (V), dependent on signal timing used OPERATING CONDITIONS Temperature 32-104º F (0-40º C) Humidity 5-95% (non-condensing) DIMENSIONS
(WxHxD) Physical 18.8" x 17.9" x 18.5"
480mm x 456mm x 470mm WEIGHT Net 51.7 lbs. (23.5 kgs.) Gross 58.3 lbs. (26.5 kgs.) WARRANTY Three-year limited warranty on CRT, parts and labor. REGULATIONS UL/cUL, FCC-B, CB, CE, DHHS, ICES 003, ENERGY STAR®, NOM, TUV/GS, TUV/Ergo, NEMKO, SEMKO, DEMKO, FEMKO, GOST-R, SASO, PCBC, VCCI, BSMI, CCC, PSB, C-tick, Argentina-TUV/S, TCO99 (P95f+B) TCO'03 (P95f+) POWER MANAGEMENT Meets TCO'99 (P95f+B),TCO'03 (P95f+)and ENERGY STAR standards
Oct 27, 2009 | ViewSonic Computers & Internet
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
When i on the PC this message appears on the screen :OSD LOCK. the type of the monitor i am using is ViewSonic E70f 17" CRT...
To enable or disable the OSD lock feature, press and hold the 1 and the up arrow for 10 seconds.
Jun 03, 2009 | ViewSonic E70f 17" CRT Monitor
Viewsonic E70f 17
Check the horizondal out put transistor if it is short replace the transistoror or replace the flyback transformer.
May 01, 2009 | ViewSonic E70f 17" CRT Monitor
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Feb 04, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
103 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
