Question about Xerox DocuColor 12 Printer
Need help i am getting 10.389 err code
    President:
  • 2,072 Answers
Fuser related issue. Over or under heating.
Needs a service call.
Posted on Feb 07, 2008
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Jun 19, 2014 | Zanussi Washing Machines
Mazda etude radio shows ERR. anyone with a fix will be appreciated
check fuse
check connections to rear of radio.
if good the Radio is inop. get it fixed.
Feb 17, 2014 | 2004 Honda Accord
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
Kenmore dehumidifier model 129-25803. I am getting err 3.
Hi, In the manual it says if you get this error err 3, please contact your authorized dealer. Hope this helps.
Jul 20, 2010 | Kenmore Dehumidifiers
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
The copier shuts down when trying to print
Look for the error code, that would lead you to the problem area, most likely the fuser assy. needs to be replaced. Do this, Press;
ADDITIONAL FUNCTIONS,
press 2 and 8 (together),
ADDITIONAL FUNCTIONS again,
You should now be in Service mode, if not hit CLEAR twice then repeat the steps above.
press COPIER,
press ERR
the one listed at the top is the error code.(write it down)
You can try clearing the code then reboothing the machine with the right side switch and it might work.
This is how you clear the code, follow all the steps above except the last one (ERR) instead select FUNCTION above then CLEAR then ERR. Turn the machine off then back on again.
If that does not help and you are still having the same problem, you could either call Canon with a service call, call a local technician or get yourself a service manual and with the error code you wrote down above try looking it up or contact us again with the error code. Good luck.
Dec 18, 2009 | Canon imageRUNNER C3220 Color Copier
Is there a way to reset the Err-3 code? How can I get the serial # when Err-3 is on the display?
Disconnect battery for about 20 seconds. When you reconnect it, you will need to enter your code for the radio. If you try and fail three times, you get that code.
Oct 20, 2009 | 1998 Acura CL
Xerox DocuColor 12 Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
