Question about Kenwood DDX-6019 Car DVD Player
Kenwood ddx6019 comeing on
With the key in the acc. postion it always comes on. But when i turn my truck on it will come on for a sec then turn off and the red triangle will flash. some time when i start my truck it come on fine and works. any ideas Thanks
Yoou've got power , but you are nt getting ignition (red wire).
Posted on Oct 18, 2008
  • 3 Answers
The red triangle is a security feature and blinks when the stereo is turned off, it has nothing to do with power warnings.
Posted on May 22, 2008
That red triangle falsh is a power warning take a meter to the accesory wire going to the radio ( its red for the love of god please tell me you know that) but anyways see whats happening there odds are you have a faulty wire it should read 12-14v dc. when you try and meter it for resistance to ground never should you see a ground spike if you do you have a problem.
Posted on Apr 20, 2008
What is a 12v acc.
1.Wire name: ACC wire
Color: Red
Describtion of ACC wire:
When you insert key into ignition switch and turn it to the left you are turning on the ACC circuit. It will allow you to operate radio, windows and other accesories, but it does not turn on fuel pump and other engine controls. It saves battery power for when you need to operate vehicle components without engine being on.
The ACC wire offers power/electricity only when you insert car key into ignition switch and turn it to the left
The ACC wire needs to be connected to car igniton
2.Wire name: 12V battery(+)
Color: Yellow
Describtion of 12V battery(+) wire:
The 12V permanent battery wire will always offer power/electricity when the vehicle is turned on or off
The 12v permanent battery wire needs to be connected to car battery.
26291025-azrw0qmg4txhvnd4c3h3ocng-5-0.jpg https://electronicshelponline.blogspot.com/
Sep 25, 2016 | Car Audio & Video
How do i reset the service counter in my 2002 mercedes ml500
Turn the ignition key 2 clicks (postion II) and then quickly push trip button twice, you should see time or mileage remaining for service.hold trip button down and turn key off, keep trip button down do not release, with trip still down turn key back on to the II postion continue to hold button for about 10 sec,you will hear the dash beep and the display will read 10000,all set release trip and turn key off. let me know the outcome. good day
Feb 15, 2012 | Cars & Trucks
How do you reset the "time for service" button on a 2004 volve V70 AWD
Turn your key to position I Hold in the Trip odometer reset button
While holding the reset button in, turn key to postion II.
Keep holding the reset button in until the warning triangle on the dash flashes, then release.
Thanks,
Lee
Oct 27, 2010 | 2004 Volvo S60
1999 jeep grand cherokee will not start.turns over but acting as if there is no fuel.
The Question is no Fuel Or no Spark. When you turn the key to the ACC postion the last click before the engine turns over can you here a buzz or a little wine come from behind you? If so you have fuel, no spark Unless fuel filter is clugged (when was that replaced last) Start there, then get back
Jun 26, 2010 | 1999 Jeep Cherokee
I am having trouble getting power to my new cd player. I have the orange battery wire hooked up, and also the ground wire is hooked up, and there is a red wire on the cd player that is a Ignition wire....
2 wires for power- one that is ALWAYS connected (remembers time, preset stations, etc.), and the other one you hook up to your ignition circuit (allows your radio to come on only when the key has been turned to ACC or RUN).
When you have wired this correctly, your radio will only come on when the ignition key is in ACC or RUN, and will ALSO remember the preset radio stations and the time, etc., when the key is turned off then back on again.
If you look at your fusebox, look for an ACC (accessory) junction that you can tap into. Also, don't forget that it's important to put a fuse in any wire you connect to a 12v+ source; don't rely on the fuse you are tapping into.
Hope this helps.
Mar 06, 2010 | Kenwood KDC-319 CD Player
Afer turning off motor ignition key stops at acc
you need to adjust the brake shift interlock cable other wise known as the bsti solenoid
Apr 17, 2009 | 1999 Mazda Millenia
Key lock cylinder won't come out....
cars have a lock position to protect the car from being stolen by theives. When we park the car with the wheels turned to the sides it gets locked in that position and the key can sometimes nbe hard to take out. Try moving the steering wheel in both directions as much as possible while pushing in the key and trying to jiggle it to turn. If you can get it out, the next time , park your car with the wheels facing forward. I hope this works.
Feb 06, 2009 | 1996 Toyota Corolla
1999 Continental will not start
Does anti-theft light come on for a sec then turn off when you turn on the key or does it flash with key on?
You said that CEL turns off while cranking,does it come back on if you continue to crank after about 8-10 seconds of cranking?
If it does not then your PCM is not seeing a signal from the crankshaft postion sensor.You can try wiggling the harness at the crankshaft postion sensor and see if it will start.
Jan 31, 2009 | 1999 Lincoln Continental
Key stuck
Under the steering colume the should be a small hole or a small cover that you can take out to reveal a small hole that you can reach up into and push on a silver cylinder type thing pulling it back towards you and that should release the key.
Jan 30, 2009 | 1998 Pontiac Grand Am
Key won't turn on in 96 4runner
stearing wheel in locked postion?
Dec 21, 2008 | 1996 Toyota 4Runner
Kenwood DDX-6019 Car DVD Player Logo
650 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
