Toshiba 27AF41 27" TV
Problem for Toshiba 27AF41 27" TV
Power light starts blinking
By andreglassey on Feb 06, 2008
I have a 27af41 and the other day it started to have a trapazoidal shape inside the picture with thin blue lines then the set shuts off and the power light starts blinking. after unplugging and plugginf back in it works for a little while then the same happens again. does this sound like a power supply issue or what should i check? sometimes it has no problem.
Same Problem
Apr 05, 2008
-   Our TV started this about 3 weeks ago and has just shut of three times on its own. Then the power light blinks and you have to unplug it to get it to work again. After it happended today, the picture lost some of its color and nothing in the setting could get it back. The Direct TV guide that use to be blue is now in green and yellow tones. Time for a new TV?-   kleeg
Feb 07, 2008
-   My Toshiba 27af41 is 7-yrs old...in the last 2-days, it started to exhibit a no vertical deflection problem (thin horizontal line)...when it first started having problems, it went away after about 5-min (warmup???), but today it continues to have the problem no matter how long I let it warmup...are the vertical IC components available ?
Thank you-   Guest
Solution #1
posted on Feb 06, 2008
Not Rated)
orlyboy
Rank: Wiz
Rating: 81%, 96 votes
replace the vertical ic.having single line is a sign that your vertical ic is need to replace.if the power indicator is blinking is also a sign of defective vertical ic
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF41 27" TV
Questions and Unsolved Problems for Toshiba 27AF41 27" TV
Do you recommend Toshiba 27AF41 27" TV?
Answer
Answer
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote.... (More)
Answer
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it... (More)
Answer
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I... (More)
Answer
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I... (More)
Answer
cant gat my older rca direct tv remote to operate my toshiba model 27af41 tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
