Question about AOpen MX4SGVI-4DN2 (91.8B810.407) Motherboard
Upgrading CPU not booting BIOS
RK80546PG0801M / NE80546PG0801M CPU upgrading 2.4
I have cleared CMOS and updated to version 1 Bios latest although will not allow me to update to latest version 2 Bios
Computer will not boot bios. Powers on and monitor stays asleep also PWR LED not on
I am pretty sure this new CPU is a good fit see model number for specs
Thanks
  • lowblowmusic Feb 06, 2008
    upgrading cpu, flashed bios
    aopen MX4SGVI-4DN2 motherboard
    new cpu intel P4 3.0Ghz 478 socket 800 fsb/1MB/HT
    computer boots fine with old CPU
    No POST or beep with new
  • andi n.
    andi n. May 11, 2010
    can you be more specific please?you already did the bios update?how did you made it?fleshing the bios or from dos mode with bootable cd?give me more information about the mainboard and the processor.(model and manufacturer)
    the computer is totally dead or not?
    thanks
    Scholar:
  • 119 Answers
Key Features
Form Factor Micro ATX
Compatibility PC
Chipset Intel 865GV
Compatible Processors Intel Pentium 4
Front Side Bus Speed 800 MHz
Technical Features
Integrated Input/Output Ports USB 1.1 x 4 • Serial Port x 1 • RJ45 Lan Port x 1 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 • Floppy Port x 1
Expansion Slots PCI x 3
Storage Controller Type(s) Serial ATA x 2, DMA/ATA-100 (Ultra) x 2
South Bridge Chip Intel ICH5
Processor
Socket Type Socket 478
Max supported CPUs qty 1
Memory
Number of Memory Slots 4 x DIMMs
Supported RAM speeds 400 MHz
Max Supported RAM 4 GB
so this is the board..no doubt that the cpu fits and is a good choice for you.
however,if the old one works fine and this one ,even if it is new,does not wiork,the only rational conclusion is that this one is malfunctioning ,maybe from the factory,or maybe one of the pins doesnt make a real contact.
check very attentive the integrity of the pins and of the cpu socket in the motherboard.
there are also some cases that the motherboard doesnt support the high Frequence of the new processor,but that was a problem for the old PCs..I doubt you have it with your motherboard.
I suggest you to bring it back and to ask for a replacement,or at least go with it to  a specialised cervice and let them check it.
sorry for not beeing a huge help to you,so dont rate my answer if you dont feel to..
bye bye and good luck..keep me up to date with your situation
bye
Posted on Feb 06, 2008
Menus Locked in BIOS of 5014c-mt super server. Cant navigate to any sub menus... How did this happen????
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5014/sys-5014c-mt.cfm
Try to reset the bios, by removing the cmos battery.
And insert it again.
This will clear the bios, to factory settings.
But you have to setup the bios again: date, clock, boot settings etc.
When you get it running again, try upgrading the drivers and bios to the latest version.
Hope this will help you.
Feb 10, 2011 | SuperMicro SuperServer 5014C-MT
How to upgrade BIOS in my XW400?
Upgrading the BIOS is an easy task but not recommended unless your computer has a problem which will be solved by a BIOS upgrade.
I assume that you are aware that a failed upgrade may render you system unusable till it is reloaded. Primary cause of a failed upgrade is a power failure so please make sure your PC has a back-up power source in case of a power failure.
The latest BIOS update can be downloaded from this website.
Download the exe file on your desktop and double click on run it. It is to be used on Win XP or 2000.
Before upgrading, check the version of your BIOS. If the version number is same as the one with you are upgrading, it means you have already the latest BIOS and it is not necessary to upgrade. The version number of this BIOS is 3.06 Revision A.
May 14, 2010 | Compaq XW4000 PC Desktop
Checksum Error after Bios Upgrade K7VZA
Have you tried resetting the CMOS? Often, after upgrading BIOS you need to clear the CMOS and re-setup to handle the new features. You should have a jumper to clear CMOS, or you can remove the power from the system and remove the battery for a few seconds to clear it.
Let me know if this clears up your issue.
Sep 19, 2009 | EliteGroup K7VZA Motherboard
Bios Failed During Bios Upgrade
pls check the RAM try re installing the RAM or try replacing them , may be it is a co incedent u thought it as a bios update failure pls check and reply back with mother board complete model number and manufacturer with processor details
and pls rate me if its helpful
Feb 24, 2009 | Gigabyte GA-K8NSC-939 Motherboard
Cpu upgrade wont happen
Ok i checked the ASUS website and looked up the CPU compatibility list for your board here:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
But unfortunately that particular CPU doesn’t seem to be supported. Must be something to do with the technology inside the CPU or the amount of L2 cache or something like that. (it would require some rather intensive research to find out exact reason why...
And when searching for ASUS motherboards that are compatible with that CPU it comes up with this short list;
AP120-E1
AP130-E1
PSCHL009
AP140R-E1
P4RD1-MX
Did you clear the cmos when installing the new cpu before powering it up?
i know the CPU you have now runs at 400FSB and the new one runs at 800FSB But that board supports both speeds so that shouldn’t be a problem.
What type of RAM do you have ?
maybe check owners manual for memory compatibility chart for new 800FSB CPU
Have you tried the latest beta bios from ASUS site :
I can not guarantee that it will work but it is worth a try.
http://support.asus.com/download/download.aspx?model=P4S800D-X%20&f_type=34&SLanguage=en-us
NOTE: Updating the bios can be risky and should only be done to resolve compatibility issues or things like that (or to add CPU support) In the rare event of a power failure during bios update your motherboard could become permanently unusable. (Always use a brand new floppy and follow the instructions to the letter when updating system bios)
Nov 22, 2008 | ASUS P4S800D-X Motherboard
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
BIOS DISPLAYING INCORRECT CPU SPEED
Hi, I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties. To upgrade the BIOS: 1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown; 2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | Soltek SL-75FRV Motherboard
AOpen MX4SGVI-4DN2 (91.8B810.407) Motherboard Logo
245 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
