Question about Tech Solution TS-4500 Shredder
Ts 4500 The shredder also makes a clicking noise when running and it runs really slow. Any help please?
  • Marty marty May 11, 2010
    most likely a paper jam and maybe this shredder has a slip clutch? to prevent motor burnouts
    Scholar:
  • 102 Answers
Actually you more than likely have a broken or stripped gear. Contact manufacturer for parts availability.
Posted on Mar 02, 2008
I have read over and over the four-page manual for my TS-4500 shredder and I cannot find information about preventive maintenance such as oiling the mechanism and/or blades. Surely, there must be a means...
Shreddrs do need to be oiled approximately every 30 minutes or so, of continuous use. Any shredder oil will do just fine. Squirt a little shredder oil onto a piece of paper that you wish to shred & feed it through your shredder. That is all you need to do to keep it oiled.
Feb 01, 2011 | Tech Solution TS-4500 Shredder
I have a tech solutions shredder. Envelope got stuck. I cleared it out. Now it will go backwards, but not forwards...although the green light does come on when I press the forward button.
There is probably paper, dust, or something still in the shredder somewhere obstructing the sensor. Run it backwards for a minute or so, then turn it over and blow it out, and after unplug the shredder and plug it back in. Then see if it runs forward.
Mar 17, 2010 | Tech Solution TS-4500 Shredder
It seems a sif soemthing is blocking the shredder
you will need to take it aprt. over time paper dust gets in the gears, transmission and bushings. you will need to remove all the dust and inspect the drive gears. mosyt of these come apart buy taking it off the stand. flipping it over, messy. removeing the bottm bolts/screws. then maybe remove trans mission cover.
Oct 28, 2009 | Tech Solution TS-4500 Shredder
Cannot open TS 4500 shredder.
look around on top or bottom for a decal or label covering. A lot of times there is a screw located under it, once you peel back the label.
Jan 17, 2009 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Problem: Shredder Switch
The phone number 1-800-639-3803 is on the bottom of my TS2550. It is . I called it today and did talk to a help desk person. Basically, they told me that my shredder was manufactured in China and they are only importers.
Hopefully thay can give you more help than they gave me.
- Wes (wcbyers)
Jun 23, 2008 | Tech Solution TS-4500 Shredder
Can't get shredder to work
Please ... unplug your shredder before doing this.
It sounds like you were on the right track picking paper out of the gears. The problem is that the paper can get really jammed up in there, especially when you use the reverse.
I found that I needed to use a combination of a small screwdriver with at least a 3 inch long blade to push the jammed paper through. The I use needle-nosed plyers to pull the paper through the other side.
Hope this helps. Please let me know if it does.
Blessings,
-- Wes (wcbyers)
May 02, 2008 | Tech Solution TS-4500 Shredder
Ts 4500 blades not moving
From the sound from your description, it is Probably a cracked gear or a worn bushing.
To get a better idea, you would have to take it apart to see what is going on inside.
Good luck
Feb 06, 2008 | Tech Solution TS-4500 Shredder
Need gear
Have you tried EBAY?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 27, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
135 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Marvin
Marvin
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
