Question about Toshiba Satellite A100-S8111TD Notebook
Keyboard possibly unplugged
My keyboard and touchpad don't work, and someone suggested that it may have came unplugged. I took off the peice between the screen and the keyboard. I see wires, but I don't see where something could come unplugged. If you could tell me where I could check to see if it's plugged in or another solution to the touchpad and keyboard not working that would be great.
    Genius:
  • 3,587 Answers
The keyboard and palm rest(touchpad) are connected with a cable under the keyboard, and a small connector for palm rest. Only way to get to em, is by unscrewing the keeper screws(small phillips should do it), and carefully raising the keyboard. Should be a slim line connector, or a clamp down type. Try that, BUT BE CAREFUL.
Posted on Feb 06, 2008
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
Touchpad problem
hello
Try this..
Go to the device manager and uninstall the keyboard and touch pad drivers..
Download the drivers from Dell's website and try reinstalling the drivers and restart the system..
If this don't work please tell us so that we can think over other issues..
Thank you
Aug 19, 2009 | Computers & Internet
Acer 6930 laptop keyboard does not work. Touchpad
the keyboard is defective. I would suggest ordering one off ebay and getting a computer shop to install one
Jun 27, 2009 | Acer Aspire 6930-6082 Notebook PC
Keyboard doesnt function properly
It is possible that the keyboard matrix is shorted so when you use the external kbd it still gets the same errors. See if you can disable the main kbd in bios and if that solves the problem. You could also try removing the main kbd and see what that does. Otherwise you probably have a motherboard problem. The touchpads are usually pretty tough to liquids - check the cable on that.
Jon
Apr 13, 2009 | Dell Vostro 1000 Notebook
My acer 3100 keyboard and touchpad arent working. any help?
It's possible that something uninstalled the devices from Windows. You can try connecting an external keyboard and mouse, then check the Device Manager to see if it flags any hardware problems.
Another possibility is that the flat cables connecting the keyboard and touchpad to the main board have come loose. To check the cables you need to remove any screws securing the keyboard and pop off the top edge trim to lift the keyboard up.
Mar 31, 2009 | Acer Aspire 3100 Notebook
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Touchpad not working
You should be able to see the touch pad connector with the keyboard off. Also, make sure the touch pad, sometimes referred to as the synaptic pointing device, drivers are istalled and working.Try this link it should help, it has breakdown diagrams for most models.
http://repair4laptop.org/notebook.html
Jun 28, 2008 | Gateway CX2724 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
