Question about ASUS P4S533-MX Motherboard
I changed RAM settings in BIOS, now I can't boot
ASUS P4S533-MX Motherboard Problem
I changed RAM settings in BIOS, now I can't boot - need to clean CMOS.
Tried to remove Battery, did not help, still when I boot, there is a looooooong beep which never stops
any help will be greatly appreciated
Jan
  • jstefano928 Feb 06, 2008
    Thanks for all help, dear friends.... Tried to remove battery, tried to reset the jumper, still the same. PC will start, 1 normal short beep, then just one loooong never ending beep, and it's frozen like a stone
    Dear Gurus!
    Thank you for your suggestions, I found out what the problem was: Even I removed CMOS battery, changed Jumper, removed DIMMs one by one, no luck, becouse..... I forgot my KVM switch is feeding Motherboard even I turned Power off....
    Geeeeeez....
    Anyway, I am back online, Millon thanks for all your great help, guys!
    Good nite
    Jan
    Scholar:
  • 119 Answers
And by the way,the reset of bios is done by switching the reset jumpers...with the computer off:)..dont get the baterry out unless it is absolutelly necessary.
after that set the data for the ramms.
bye
Posted on Feb 06, 2008
  • andi n.
    andi n. Feb 06, 2008
    the diagram for the position of jumpers youll find in the user manual of the mainboard.if you dont have such a book download it from the official asus site,like a pdf.
    do not do this without a strict knowing of the possition,or you will deliberately burn your board..
    good luck..bye bye
    Master:
    Sergeant:
  • 440 Answers
Try jumpers ok move to 2 and 3 for few sec then back on 1 and 2 pins on mobo ok thx nick take ram out do one at time defult to auto in bios thx nick
Asus P4S533-MX Bios problem
The average life span of a cmos battery is about five years.
The Asus P4S533-MX mother board hit the market in 2002/2003. Suggest you pull the bios battery and check its current voltage. It should read 3 volts DC. Double check the bios jumper. The jumper should be across pins 1 and 2 (This is Normal default setting). Open you're manual to page 1-15 for more information about the bios jumper. (CLRTC1). When in the bios you should set the time and date to current date and time. Save and exit the bios. When you boot your system and the bios auto loads it's self automatically usually its due from a wrong setting within the bios or its not maintaining its voltage. Consider the price of a new battery. See the link provided;
http://www.google.com/products/catalog?hl=en&q=cmos+battery&cid=7067940192546936833&sa=title#p
If you need the manual or drivers try the link provided;
http://support.asus.com/download/download_item.aspx?model=P4S533-MX&product=1&type=All&SLanguage=en
Happy holidays!
Mike
Dec 31, 2009 | ASUS P4S533 Motherboard
SYSTEM DOESN'T BOOT UP, GET LONG STEADY TONE WHEN SYSTEM STARTS
please check the system memory (RAM)
remove them and carefully clean in mouth with a clean A4 white sheet
or change the memory if possible...... and if problem still occur, please check the system processor too...
to check if the processor is functioning, remove the heat sink on the processor and boot the machine placing your finger on the processor chip.
it burns your finger after a short sec. BUT this should be done in a controlled way and after the memory had been tested for
May 10, 2009 | ASUS P4S533-MX Motherboard
Asus p4s533 will not boot after replacing fan + heatsink
Try to remove the processor, then clear it with contact cleaner, then plugin it again..
There isn't beep : Processor, and long beep is memory..
Hopefully this be of some help/idea..
Nov 25, 2008 | ASUS P4S533-MX Motherboard
ASUS P4S533 Motherboard 1.77GHz CPU does not boot with 1GB DDR400 RAM
Make sure you are using the supported memory type. Check the user guide. Also check if you have installed the latest BIOS firmware from ASUS.
Oct 30, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
BEEP
Did you try resetting your BIOS. If you havent then reset your BIOS and try to start the computer again. If it doesnt start then there is problem with memory.
Try another slot(PC has two slots for RAM right) if it still doesnt work then you may have to try replacing your RAM.
Oct 28, 2008 | ASUS P4S533-MX Motherboard
My computer does not boot from the ide section on the board but when u remove
I need more info. When did this problem occur? Was it working properly before? Did you change anything in your CMOS/ BIOS settings?
Oct 07, 2008 | ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
Aus p4s533-mx
What setting are you changing?
Jun 03, 2008 | ASUS P4S533 Motherboard
well its quite simple.you have set the wrong latency for rams.
I suggest you put a latency around 3
reset the bios and check the latencyes..you know that you must have all the rams from the computer to the same data..like all the timings or latency.
good luck..
bye bye
Feb 06, 2008 | ASUS P4S533-MX Motherboard
ASUS P4S533-MX Motherboard Logo
282 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
