Question about Whirlpool GEW9250 Electric Dryer
Drum light works - contol lights don't/can't start dryer.
Everything was working great, we lost power to the house.
When power came back on, this was my situation - drum light comes on but control lights don't work and I can't start the dryer.
Is there a reset button or?
  • mypainter Mar 02, 2008
    settings lock light on ,inside light is on but no start. power outage the day before.
    Novelist:
  • 131 Answers
Either the machine control, or the user interface. Further diagnosis isn't possible. I'd try the machine control first. It's just under the top panel, along the left side.
Posted on Mar 10, 2008
Dcvh515ef0ww no power no light
probably the door is not activating the "door closed" safety switch,
Dec 24, 2013 | GE Dryers
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
My dryer drum won't turn but the electrical panel is lighting up
it is most likely that the belt inside the back of the dryer is broken or loose.
unplug the dryer and remove the back cover of the dryer. it should look something like this:
although the is for a different make of dryer, it should be similar.
Mar 08, 2012 | Kenmore Elite HE3 Steam 8676 Dryer
Dle7177wm filter light on dryer will not start
The filter component is located directly inside, bottom, behind the door. Looking at it from the inside, you will see 4 screws. Two will be close to one another remaining two, one on each side. Before you remove the screws make sure you have removed the lint slide that sits in the filter housing
Carefully with not too much force the filter housing should come off in 3 parts. The smallest and most lover peace will have 2 metal strips running flat parallel to each other on the plastic housing which is attached to a white connecter, carefully remove it from the connecter, remove all pieces out of the drum, clean thoroughly, vacuum cleaner will work great, however you will need a sharp and narrow instrument like a small thin screw driver to pull out dried up lint from small areas.
Once completed put back the connecter, put all parts into place screw back don’t use force if screws are tight, undo the screw, and slightly move the parts to make sure the screws tighten in place.
Make sure you have a general idea how to put parts back in place as you remove them.
Jul 12, 2010 | LG DLE7177 Dryer
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Kenmore Elite Electric Dryer, Model # 110.8586400, Control Panel Lights inoperative, But Drum Light works fine. I am going to try this procedure, Will let you know if it works. Jay/ Jacksonville Florida...
I followed that procedure, Taking the Electronic Control Unit out of the dryer, Blow Drying the printed circuit Board (PCB) Board out and reseating P3 and P4, Worked fine.. No moisture was found in the Drum area. I forgot to tag the TECH SHEET FOR this particular dryer . But punch in Tech sheet , Part # 8546206 into google, this gives Schematic and valuable Troubleshooting steps, The only thing i could not find was the pin to pin test on chekcing the individual switches on the main functions, Suppose to be 14 pins I only found 13. But in all drying the PCB board and reseating the plugs worked for me. Again the symptons were no Light indication on ANY button depressed but the drum light was on. Great Site, Not a first time user
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Won't Start
do you have the power cord correctly hooked up and have the correct voltage ? is the white wire in the middle? you should have 120 volt with red-white . 120 black- white and 240 black-red... careful with electricity it can hurt and kill you. let me know if you fix this one...krazytech
Sep 16, 2007 | Frigidaire AEQ6000ES Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
358 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
