Question about Delstar DS 31024 MP3 Player
How do I access shuffle mode??
I can not for the life of me find where shuffle mode is. Any help would be awesome.
  • br75 Mar 15, 2008
    I have the same problem on a Delstar ds-1036 - I cannot locate the "Playing Mode" submenu so I cannot access the repeat one / repeat all / shuffle / random modes. Any help would be wonderful! Thanks.
I think I found the solution... to get into the "playing mode" submenu, a song has to be playing when you hit the mode select button. Otherwise, if a song is stopped/paused, you get the "stop mode" menu.
Once in the "playing mode" menu, select "repeat", and then scroll all the way to the right to get the shuffle/random mode.
Posted on Mar 16, 2008
How do i unlock my ipod shuffle
if your password dosen't work then the only way to access your ipod is to firmware restore it with DFU mode.
After that use your icloud email pass to access your phone(icloud isn't necessary if u havn't set it in the first place ).
Feb 01, 2017 | Apple iPod shuffle 1st Generation (1 GB)...
I bought an AGPTEK GO2s and carefully downloaded 31 complete albums in the order they were released. But the player is playing ALL the songs out of order. What do I need to do in order to fix this.
4. Play mode - While it's on music playing interface, click the (button in the blue box) to access to its sub-menu. - Choose from the three play modes "Repeat", "Shuffle", "Repeat Settings" according to your need. Note: The shuffle/repeat function only works for the audio files in each separated folder.
http://images.agptek.us/Download/mannual/A12%20EN%20Manual.pdf
26354717-1xgjsougzksfoatycggrr2j0-2-2.jpg Hope this helps?
Nov 14, 2016 | Audio Players & Recorders
My ipod shuffle 2nd generation is not charging, when i put it in the charger it has a flashing orange light and never reaches the green light help please!!!!!!!!11
The battery in your iPod Shuffle has apparently reached the end of its usable life.
There are directions, replacement parts, and tools available at ifixit to allow you to replace the battery:
http://www.ifixit.com/Guide/Repair/Installing-iPod-Shuffle-2nd-Generation-Battery-Replacement/3656/1
Please click the link above for the repair instructions and links to parts and tools needed.
Jan 05, 2011 | Apple iPod shuffle Second Gen. Silver (1...
My i pod plays a few seconds of a song and stops!
Your I-pod is in "shuffle mode". To remove it out of shuffle mode, turn the shuffle mode switch to "off" This switch is located on the bottom right side of unit.
Apr 15, 2010 | Apple iPod shuffle Second Gen. Silver (1...
Help me with my mp3 player's problem please
The shuffle mode is in the menu, so you need to get to the menu to change it. You might try to use a toothpick or ballpoint refill to click the menu switch.
Mar 12, 2010 | RCA Audio Players & Recorders
I have an ipod shuffle i was just using it 2 days ago i tried to plug it in the computer and its doing nothing it wont charge and nothing is comming up.
What generation is this ipod, and how long have you owned it?
If it is more than one year old; it is most likely that your batteries life has expired.
With this model it is recommended to replace the unit rather then the battery as they are so close in price.
Feb 15, 2010 | Apple iPod shuffle MP3 Player
How do I turn the shuffle off?? I go to settings, choose music options, choose shuffle and highlight "on" and nothing I hit makes it change to "off". Help!!
For the Sansa Fuze, the selection Shuffle Mode is correct, just like you told:
In Main Menu > Music > Submenu > Music Options > Shuffle Mode:
1. Select Shuffle.
2. Use thumbwheel to choose Shuffle on or Shuffle off.
(to play songs in random order, set Shuffle to ON).
3. Press Select to change the Shuffle mode.
See page 9 (=page 6) of the manual in pdf format for the Sansa Fuze:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Thumbwheel: 5
Select button: 9
Jan 07, 2010 | SanDisk Sansa Fuse MP3 Player
When i connect my shuffle ipod to pc only red light apears what shoud i do
Initially try reset method
  • Disconnect iPod shuffle from the computer .
  • Move the switch on the iPod shuffle to the OFF position.
  • Wait 5 seconds.
  • Then slide the power switch on
If a red light is still blinking the battery life is over .It is time for new ipod .The battery life of Ipod is roughly 2 years .
Hope this helps .
Thanks for using Fixya.
Shane
Dec 07, 2009 | Apple iPod shuffle Second Gen. Silver (1...
My new ipod 8gb has a really short life
If you put your iPod as "shuffle" mode, then it will use up more battery since the unit has to access the hard drive more than usual.
if you put in in "repeat" it will also use more than usual battery.
So, try to put your iPod right down, but your stereo up. Also, types of music files (wmp, mp3, mp4, wav, etc) affect your battery life as well. the higher the bitrates = more battery usage.
Also, try to keep using the iPod until it goes down to absolute 0% and turns itself off. Usually, the red part will last around 8 hours in most cases.
Hope this helped! ^_^ Have a great day~
Jun 26, 2009 | Apple iPod nano
Samsung yp-u2j shuffle
Hold Down The M (Menu button) Scroll down to settings, select play mode. Exit out of he menu, press the user button until the squiggly cross with the A appears. Whalaaa you're in shuffle Mode. I hope this was a detailed solution.
Jun 14, 2007 | Samsung YP-U2JQB MP3 Player
Delstar DS 31024 MP3 Player Logo
116 people viewed this question
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
