Question about Mitsubishi WS-65809 65" Rear Projection Television
Mom's tv first, my appologies, mom gave me wrong model #. should be very comparable.TV is model # ws-65869, serial #111756.the work order specifies that greenLED light blinking, no pix, no sound.here is his evaluation : part failure - disable set to check per STAC red arccing line on left side of tv,approx. 3 " wide, depending on wich channel she was on. SO, after finally getting this info,(that she didnt think mattered),she said repair was done by sears and he did remove the back, cleaned and saudered "something" that he thought would fix it, without charging something he said cost 400.00.he was on the phone with his tech support alot.mom says he was young,helpful, but a bit inexperienced.she thinks the tv is beyond repair. tv was purchashed march,2002..... I have called sears 8004myhome (did the work,not helpful at all)
  • kldeamer Feb 06, 2008
    looking at her set,in the front ,she sees system reset,timer,power,volume,channels,(2 buttons
    enter,menu,A/V reset,and device
    ok, she doesn't see input button.is this on the front or back of TV?.(or remote).
    fuses easily accessible?
    please keep in mind i am playing phone tag with mom to extract all this info. ,thank you for your patience and time
  • Mitsubishi Master
  • 8,617 Answers
Okay check the self diagnosis feature, Hold the input and menu buttons in at the same time on the set, hold for 5 seconds see if the set blinks 1-2 blinks pauses then blinks 1-4 blinks. If so let me know the number of blinks. If not check the following items in the power supply for being open or shorted.
R9A02 R9A22 R9A23
Check Q9A51 Q9A22 also its diodes D9A31 and D9A32
Also check the 3 fues F9Doo, F9A01 and F9A06
Also check the solder on T9A20 and the flyback . Let me know what you find.
Posted on Feb 06, 2008
  • Sonny Berry
    Sonny Berry Feb 06, 2008
    Press menu and device
  • Sonny Berry
    Just have her push the device and menu buttons in together on the set itself. Some models have input instead of device.
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Picture is completely out of alignment, went to do
It means the convergence IC gave up already ang needs a replacement. And also check the 5A picofuse in the power supply.
Dec 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Tv blinks out when front buttons are pushed. model#ws-65511
If the TV is turning on and working regularly, but power button does not shut down and buttons on TV do not work, then it is a faulty touch control (button) board on TV.
If instead the TV does not even turn on, then tv is on protection mode, in that case it can be any internal fault.
If instead the problem is with remote buttons, then it is either a faulty remote or a faulty IR sensor.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
