Question about RCA Televison & Video
RF output problem
The DVD player/recorder I have recenfly purchased has no RF signal output to the TV through the coaxial cable. It does allow signals from the satellite/cable unit to pass through it to the TV. I cannot pull up any menus or play any DVDs from the unit at all. I've tried different coax cables, unit settings and various channel settings as prescribed by the user manual to no avail. I am an electronic technician and am capable of performing
most hardware technical manipulations if required. I do understand there
has been some problems with this particular type of unit that I own. Also,
it is a factory refurbished unit. I would appreciate your suggestions and
help to solve this problem. Thanks
Hugh
HAVE SAME PROBLEM WITH TWO UNITS, NO OUTPUT...
Posted on Jul 06, 2008
Can't find where to connect for dvd. no white,yellow,or red plug.
Hello, Thank you for the opportunity to help
Sounds like you got a pretty old tv there, its frustrating not to see the RED/WHT/YELLOW plugs on it. This is because this tv was made when that was not out yet. So are you out of luck? No, you ar in luck but it will cost you a little money.
You can purchase one of these RF modulators at Radio shack for like $29.95.
OR
If you have a VCR, Generally they have these plugs out the back of them you would plug the DVD into the VCR in the Video IN. You're TV will need to be on channel 3 or 4 (dending on your vcr) You vcr will need to be powered ON then tuned to VIDEO INPUT. You can do this by using the remote's up/Down channels buttons or pressing input on the remote depending on the VCR.
The VCR will need to be connected to the TV's coaxe port on the back, That port looks like this:
If you do not have a VCR you would purchase a RF modulator you TV will need to be on channel 3! The modulator is connect to the port pictured above above. The DVD is then introduced to the ports on the back of the modulator witch looks like this:
rulds2008_40.jpg WE hope you found this Very Helpful. This was answered by a human being, That works hard answering FREE questions just for a Thank You!
Regards,
Rulds2008 "ED"
Jan 27, 2011 | Zenith Z19A11S TV
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
Connection to my old TV
your tv do not have an audio/video input...what you need is a device called RF modulator, it converts the audio/video signal from your dvd player into RF signal similar to the signal from the cable operator.it has an audio/video input and a coaxial cable output..
Jul 18, 2009 | Curtis DVD1047 DVD Player
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Need an RCA Adapter for a TOSHIBA D-VR610KU
    If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
    Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
    No RF signal output to the TV through the coaxial cableIs, is that normal?
    Yes. This unit only relays the TV signal...the coaxial output can't be used to watch DVDs or play the DVR, all operations are done via the component, composite, or S-Vid outputs. The coaxial simply passes the TV signal out as in from cable TV to DVR and from DVR to TV. If you still do not get an RF signal to pass through th unit, check the cable to make sure the wire is not bent or brocken on either ends.
    Jul 14, 2008 | RCA DRC8030N
    How to connect my dvd & vcr with the converter box
    Here is my setup.
    1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
    The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
    To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
    To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
    To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
    To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
    May 06, 2008 | Insignia Digital-to-Analog Converter for...
    Need directions to install a dch70 box to tv
    dear woolifer ,
    I am not an expert but i hope i can help you..
    is it youmean digital cablebox?
    if it is try this-
    This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
    As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
    1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
    2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
    3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
    4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
    5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
    This should be all you need to get started watching your digital television. In simple terms here is what you did:
    Coaxial from wall to cable box
    Cable box to VCR
    VCR to RF modulator
    DVD player to RF Modulator
    RF modulator to TV
    You will only be able to record what is on channel
    Apr 09, 2008 | Computers & Internet
    Televison & Video Logo
    48 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
