Question about SanDisk Sansa E280 MP3 Player
Can't install MTP drivers
I've just bought an e280 version 2 and can get my computer (running XP pro service pack 2 with WMP 10) to recognize it as a drive only by using the "secret handshake". The device manager shows a driver error next to the device but will not install the MTP driver from the installation CD.
I've had driver problems with other MP3 players ever since I installed a microsoft lifecam webcam so it might be something to do with that, or it may be a coincidence.
I'm also having trouble syncing in WMP - some tracks work fine, some tracks give the error "The server threw an exception". There doesn't seem to be any logic to which files will sync and which won't - for example different tracks on the same album will sync or not sync.
Thanks
  • 1 more comment
  • ripper82 Jun 29, 2008
    Hey, I think you are right about the Microsoft webcam.
    I was using my Sansa Fuze just fine for a week (MTP mode with Windows Media Player), then I installed the giant 117MB driver for my LifeCam VX-3000 webcam, and afterward Media Player wouldn't recognize my Sansa Fuze or my older Sansa e280. I restarted a few times, tried different USB ports, nothing worked.
    Then I did a System Restore back to before the install of the LifeCam driver and, voila, the Sansas work again.
    Now how am I going to use this webcam...
  • Anonymous Sep 20, 2008
    Hardware Wizard says a service section in the INF is invalid
  • Jean Sintulaire May 11, 2010
    Have you tried to upgrade to WMP11?
As I like MTP mode a lot better than MSC (I can use WinAmp to sync and it doesn't have to restart and refresh its database after disconnecting) I didn't like a lot of the solutions to this and similar problems telling to go to MSC mode.
However, I was able to go into Device Manager (right click on My Computer, click Properties, select "Hardware" tab, click Device Manager) and find the Portable Devices sublist, right click on "Sansa e280" (it had a yellow exclamation point on it) and click install driver. I followed this through, selecting automatic installation for the driver, and presto! Sansa is installed and ready to go. I actually had Windows Media Player open during this process, and while it wouldn't recognize it before, after doing this process, I went back to WMP and it had already found it and was trying to get me to sync it. So if you like MTP, try this. It worked for me.
(Note: this method may not work, unless you tried to plug the player in and it told you that there was an error in setting up the device. My problem was that I had installed WMP 11, but had not done the final "setup" process. After I had run WMP 11 for the first time, I was able to do this successfully).
Posted on May 23, 2008
Installing WMP 11 seems to have fixed the syncing problem, so thanks for that. I installed the firmware updated and have the latest version of the firmware but that hasn't made any difference.
Since the secret handshake works fine to get the device recognized, and the syncing now works, it's not a huge deal, but it would be nice for windows to just recognise the device automatically.
Posted on Feb 08, 2008
Have you gone to sandisk.com/support and checked out the firmware update? This may be helpful to you. Just go to http://www.sandisk.com/Retail/Default.aspx?CatID=1376 and download the firmware update.
I would do this right away regardless. It will download any new firmware updates there may be in the future as well and keep you current.
Hope that helped!
884Fearless
I just bought a Sony NWZ E354 mp3 player. When plugged into my usb front main port, computer sees it as MTP device but disables it. I' running Win XP Pro and WMP 11. Take same player and its...
I upgraded my usb drivers -- I have windows xp pro -- i think they use all the same -- I used Realtek USB 2.0 card reader drivers. ( http://bit.ly/qeofyZ ) plugged it in (NOT in the front, but the back)_ & it recognized it after going to start, computer as "walkman" -- did a right click explore & all the data/music was still on the hard drive. then it showed on the walkman that it was charging & the battery was dead. i was previously using an AC usb adapter (plug in the wall) & it didn't seem to be charging it correctly -- so the computer works out for me & will only use that from now on -- fully operational.
Jul 14, 2011 | Sony Ericsson Audio Players & Recorders
Tip
XP would not recognize my e250 (new version)
The latest version of the Sansa E250 only has one mode... MTP. USB mode has been removed. My windows XP laptop would see the device and install it fine, but Media Player, Yahoo Music, and any other software would not recognize the MTP device until I installed Windows Media Player 11.
Once installed, even Yahoo Jukebox recognized the device.
I returned 1 & got a new one before I tried this solution. So if you're having a similar issue, don't return it until you've tried the latest version of WMP.
Hope this helps.
on Dec 04, 2007 | SanDisk Sansa e250 MP3 Player
My Samsung YP-S2 Mp3 player can't be recognised by computers when I plug it in through the usb input (it used to work), therefore I'm not able to upload music on it anymore. How can I fix this bug?
Samsung Player Is No Longer Detected By Windows XP, Vista, Emodio Or
Samsung Media Studio.
When your computer doesn't recognize your Samsung MP3 player, programs
such as Samsung Media Studio (SMS), Emodio, Windows Media Player
(10 or 11) do not allow you to transfer files to your player.
In SMS and Emodio, the portable icon appears grayed out.
In Windows Media Player, you are prompted to connect a device.
Your PC may fail to recognize your player for a variety of reasons.
To begin troubleshooting, scroll down, and then click the operating
system your computer is currently running.
General Operating System Information
On Windows computers, Samsung MP3 players require at least Windows XP
Service Pack 2. If you have an older operating system such as Windows
2000 or Windows 98, your computer won't recognize your player until you
upgrade your PC to at least Windows XP Service Pack 2.
If your PC is running Linux or MAC, it will not recognize some MP3
players that support only MTP mode. However, it will recognize players
that support UMS mode and list them as mass storage devices.
The following Samsung MP3 players support UMS: YP-U1, YP-U2, YP-U3,
YP-U4, YP-U5, and YP-S2.
The following Samsung MP3 players support both MTP and UMS mode: YP-Z5
and YP-P3.
Windows Vista may fail to detect you device if the player is not
connected properly, Windows Media Player is not installed or has become
corrupted, Vista is unable to install the MTP drivers, or the MTP patch
is not installed.
You can check it out further by going to this website and entering the information about your player
http://www.samsung.com/us/support/#
Please rate me.
Jan 15, 2011 | Samsung YP-S2 MP3 Player
Can not install MTp device
The best method of installation is to run the installation CD first, and THEN plug the mp3 player into the computer.
If that fails, I would try downloading the MTP Porting Kit from Microsoft's website - I wouldn't suggest this, except that both of your player's are doing the same thing.
-Tha Mp3 Doctor
Feb 18, 2009 | SanDisk Sansa E280 MP3 Player
Computer does not recognize the Insignia NS-2V17
The problem is after service pack 3, xp pro does not recognize MTP devices any longer
  • Click on the Start button and Select Settings. Then click on Control Panel.
  • Double click System, and then select the Hardware tab.
  • Click on Device manager.
  • Click on the '+' for Portable device and you will see "Insignia Video Player".
  • Right click and select "Update driver".
  • A Hardware Update Window will open, Check the "Install from a list or specific location" checkbox and then click next.
  • On the next screen select "Don't Search. I will choose the driver to install".
  • Click next and then you will see a window showing multiple drivers, Select the "Portable Devices" driver and you can select MTP or USB mass storage.
  • Select "USB Mass Storage Device" and click next.
  • XP will finish installing the driver and you MP3/video player will appear and your device will now appear as a hard drive(s) (if you have a memory card) on your system.
  • Windows Media Player and other application will now recognize your device.
Jan 08, 2009 | Insignia NS-DV2G MP3 Player
Nothing pop's in my screen comp,
I think I got it guys. forget WMP 9,. 10 , 11... I run win xp service pack 2 and could not install the samsung yp-u3 player. I kept having it found as a new hardware {portable device} but as we all know this software has no drivers, and the windows update produces MTP device error. Resulting in you not being able to see your player in XP. Well go to windows update site and search for a file called "mtppk12.exe" I'm pretty sure once you install that file and reboot, you will no longer have MTP device errors. However, I installed this at the same time i installed windows media player SDK. So maybe both files are required. Finally after 2 days of troubleshooting i got mine to work.
Jul 28, 2008 | Samsung YP-U3 MP3 Player
WMP 11 validation issue
Windows Media Player is a feature of the Windows operating system and cannot be removed entirely. However, depending upon which version of the Player and Windows that you are using, you might be able to roll back to the version of the Player that was previously on your computer. The procedure varies depending upon which version of the Player you are running.
If your computer is running Windows XP Service Pack 1 (SP1), Windows XP SP2, Windows 2000 SP3, or Windows 2000 SP4, you can use the Set Program and Access Defaults feature to remove links to the Player on your computer. Note that this does not remove the Windows Media Player software. To remove access to the Player, do the following: 1.
In Control Panel, double-click Add or Remove Programs.
2.
Click the Set Program and Access Defaults button, and then choose a configuration (such as "Non-Microsoft" or "Custom").
Mar 02, 2008 | Computers & Internet
Sansa e250-MTP Driver
MTP driver kit is located here.
MICROSOFT
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
Dell DJ Gen 2 Won't connect
if your Dell DJ player is no longer recognized by the upgrade firmware even with the correct, original device driver installed, then you will need to install a windows 'MTP' driver by doing the following. Note that this applies to Windows XP only.
1. make sure you have the SP2 XP upgrade.
2. Install Windows Media Player 10 or roll it back to version 10 if you are using a later version. You can roll it back by going to 'Add or Remove programs' and uninstalling any WMP upgrade from the 'Change or Remove Programs' dialog window. Note: don't uninstall WMP enitrely from the 'Add/remove windows components' dialog.
3. Go get this file: fixup.zip Unzip it in a temporary directory and run the fixup.cmd by double-clicking in explorer or using the windows 'Run' command. Follow the instructions it prints in its DOS window about deleting the Dell device in the hardware manager.
4. plug your DJ player into the USB port. XP should now say 'Found MTP device' or something similar.
5. Get the Dell DJ 1.02 firmware from their support site appropriate for your player. Run the firmware upgrade. The software should detect your player this time.
A good reference for the Dell DJ stuff is here: gotzune.com
Note: I can't personally recommend the 'PlayForSure' firmware as I have not been successful upgrading to it. WMP 11 does not seem to work with the Dell DJ but WMP10 does and the device Sync function works just fine.
For almost ALL of the MP3 players out there that seem bricked due to a firmware upgrade failure or some other reason, they can be usually restored in a simlar way by installing a basic 'MTP' driver which allows windows to at least send a file to it, and by putting the player into a recovery mode as defined by the manufacturer.
Sep 24, 2007 | Dell DJ MP3 Player
MTP device not found in XP with WMP 11
solve your problem from my post:
http://amritbera.blogspot.com/2008/11/mtp-problem-solved.html
May 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
1,891 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
