Question about Hitachi 50DX20B 50" Rear Projection Television
Colors seperating when unit first powered on
It seems like the blue colors are seperating from the rest when the TV is turned on. It goes away in 1-4 minutes. It just starte4 days ago and does not happen each time, but is getting more frequent. Thsi TV weighs 225 pounds and is downstairs, so hopefully I can repair it here. I am well versed at schematics and soldering as I repaired military aircraft for many years and now am a computer tech.
  • 2,326 Answers
I would suggest to check the following link for a schematic diagram that may be close to your model. I do not think they have changed their design much only the model numbers just to add more features or charge more.
You will need to change the convergency STKs to restore the distorted colors. Check the low value resistors, fuse esistors that are connected to the ICs leads.
Those parts are mounted on a heatsink, they have normally 18 to 20 leads depending on their numbers.
Hope this helps.
Good Luck.
Posted on Feb 06, 2008
Color problem on Toshiba CRT TV
It sounds that the color mask inside the picture tube have been displaced due to hard shock. If so, it is irrepariable.
May 28, 2013 | iLO 2600 Television
In the middle of watching tv, the screen just turned blue. We went to change the channel and as soon as we did, it turned blue. It doesn't have sound either.
Blue color production circuit is fine. Red and green color circuit not getting power, the same power also goes to sound unit. if that is rectified, issue would be resolved.
Dec 17, 2010 | Maxent Televison & Video
Watching tv/w a dvd/vhs player(a seperate machine)the power goes out on the screen.went out with a white flash like usually when i turn it on the bottom where the control buttons are,a red light...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Blue d52wlcd
The other stuff is probably the Engine as well. Before going any further, have them replace it again and see if the other problems show up. I am willing to bet they wont. These Engines are mostly refurbished units and if they originally had intermittent problems on the Digital Board that comes mounted on the Engine it would get passed on to you.
I would not wait before having it replaced and I would Call LG first to let them know you got a dud replacement Engine. Let me know how it comes out.
Aug 29, 2009 | Zenith D52WLCD 52" Rear Projection...
It seems that my westignhouse hd lcd tv gets too hot and starts showing blue patches ; mostly where it should be white.
have the same prob! Seems to get too hot then the pictures goes to hell and colors are jumbled up everywhere on the screen! turn it off for a while and let it cool down then it plays fine til it gets too hot again! i put a fan in the back of the tv and turn it on while i watch and it stays on with no probs! its DEFINTIELY a heat issue
May 17, 2009 | Westinghouse SK-32H240S Television
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Blue doesn't seem to line up
Blue convergence IC is bad....change both,,,original number
Stk392-110 replace with upgrade Stk394-160E Hitachi part
# CZ 01341 ....also check B+ feed resistors for over-heating
Jan 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Color problem
i think it seems me is due to degaussing problem. solution 1 do not turn while tv is on. 2 do not keep any thing which has got magnet like speaker or headphone very near to it. if it is so put off tv for 15 minutes& put on it will be ok. good luck.
Oct 06, 2007 | Toshiba 27AF45 27" TV
Hitachi 50DX20B 50" Rear Projection Television Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
