Question about Akai PT5250A Television
High definition cable hookup
Once I hook up my hd cables for my xbox 360 to the tv I dont get an hd picture. Is there a switch or something in the set-up?
  • 113 Answers
There is a switch on the 360 hd cables themselves it is a slider to go from TV to HD it is right where the cable plugs into the 360...switch towards 360 is tv and away is HD. Hope this is what you needed.
Posted on Feb 06, 2008
Hello. I have the HDTV ready hookup for my xbox so all i have to do is switch it from tv to HDTV and it will switch over. My hookup has a green, blue, 2 red, 2 white, and a yellow hookup. i hooked in all...
pay attention on how you hook them into the xbox..and if you are sure this is the way ..than switch to another HD input on the tv ...usually they have 3 HD channels..but not all work ...cause ar eon different frequencies or something like that ..Just try them all ..be sure you make the right choice in the channels too on the Hd of the tv ..
Aug 28, 2010 | Computers & Internet
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
I have a jvc i'art tv. model # av-27f476. i have an xbox 360. how do i hook em up? i have plugged the red, white, yellow cables to the corresponding colored jacks on the front of my tv. i turn my xbox 360...
on the xbox i think the hd works with all 6 cables connected so you will need to switch it back to standard definition. if its still not working try it via scart m8
Mar 06, 2010 | Video Game Consoles & Games
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Xbox 360 no picture
Try looking on your AV Cable there is a setting for HDTV and TV if you have a High Definition tv use that setting but by the sounds of your issue i would say you dont and would go with the regular TV setting. Its right on the neck of the AV cable where it plugs into the game console. Let me know if this works for you.
Dec 26, 2007 | Microsoft Xbox 360 Console
Akai PT5250A Television Logo
106 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
